![]() Join Date: Oct 2013
1994 240sx / rb26 swap / cd009
This has been parted out and sold, MODS CAN CLOSE.
Title in hand. Car does have light rust, but is absolutely a useable chassis. The strut towers and frame rails are in very good shape. This was a complete drift car, and the suspension / interior has been parted out. I have compression test videos from 7/31/2021, as well as a cold start video from 8/4/2021. This is a chassis with a complete swap. It does NOT have axles, diff, alignment, brakes, e-brake, good ball joints, etc. It is to be purchased for the complete swap, or a project car. I have receipts from RPE Machine LLC for the engine build, as well as receipts for the internals. The car made 523/ 391TQ at Performance & Styling in Manchester, CT on its current tune. -RB26 05U Block -Nitto Crank Collar -Nitto High Volume Oil Pump -Tomei Oil Pan Baffle -Ross Tuffbond balancer -ACL Race bearings -Manley H Beam Rods -CP Forged Pistons. 86.5mm / 9.0:1 -Tomei 1.2mm head gasket -Kelford 272 Cams -Kelford Valve Springs -Tomei Adjustable Cam gears -Nitto -10AN Head drain kit -DC Power High Output Alternator -Toyota MR2 Power Steering pump -Injector Dynamics ID1000 Injectors -Tomei Fuel Rail -Full Race Turbo manifold, T4, Twin wastegate, Ceramic Coated -Precision 6466 GENII Turbo, T4 in, V-band Out -(2) Tial MV-S Wastegates -Tial Q Blow off Valve -CD009 Trans -Serial 9 Shifter -Jim Wolf Bellhousing Adapter -Jim Wolf Adapter Flywheel -Jim Wolf Clutch -Wiring Specialties PRO Universal Harness -AEM V2 ECU -AEM Uego Wideband -AEM Boost Gauge -One Piece driveshaft -Mckinney motor mounts -4PT Welded Roll Bar The list goes on and on. If you've made it this far, you get the idea. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by tuzzio; 09-09-2021 at 07:58 AM.. |
Did I miss a price? How much for all and how much for the swap?
