SUPERSTREET Lexus Gs300, Manual, 2jz, Caged, Stree, Track, Drift, Show car
Chassis 150.000miles Motor: 5,000miles
Engine: 24psi 91oct 624whp 562tq Comp turbo CT4:6265 triple ceramic ball bearing Wiseco pistons ACL bearings ARP rod bolts Cometic head gasket HKS cam gear Gates racing timing belt ARP head studs Fully rebuilt head with mild port and polish ATI super damper Custom intake manifold First state motorsport dual feed fuel rail Osidetiger 720cc injectors Aeromotive 340lph fuel pump Tomei fuel pressure regulator HKS style 50mm waste gate Tial 50mm blow off valve AEM v1 standalone ECU AEM air temp sensor AEM map sensor AEM methanol injection system T3 manual boost controller Drift motion 2jz exhaust manifold Drift motion lightweight pully kit Greddy 10 row oil cooler Dual flex a lite cooling fan Custom inter cooler piping by Spoolin performance Custom oil catch can by Spoolin performance Custom coolant catch can by Spoolin performance 3in exhaust all the way modified by Spoolin Performance Drivetrain: Rebuilt r154 transmission Marlin crawler billet 3-4 shift fork Marlin crawler billet 1-2 shift fork Marlin crawler thrust washer Marlin crawler heavy duty bearing retainer ACT extreme 6 puck clutch kit Drift motion lightweight flywheel 11.5 lb Custom extended shifter housing Custom 1 piece 3in steel driveshaft Custom billet aluminum diff adapter Brakes: Front- Stoptech rotors, and pads Rear- 324mm Willwood BBK kit Suspension: Powerd by max coil overs 18kg 16kg 40mm front RCA Top speed front under brace SPC front upper control arms Front and rear blue TRD stabilizer bar Battle version Aluminum steering rack bushing Battle version rear upper control arms Battle version rear toe arms Battle version rear traction arm Battle version solid differential bushings Ikeya formula subframe risers Interior: Full custom 6 point weld-in cage NRG short hub NRG quick release Nardi 350mm deep corn leather Glow shift gauges, boost, oil pressure, oil temp AEM wideband ASD hydraulic e brake x2 Bride zeta III bucket seat Bride MO seat rails x2 Takata 4 pt seat harness 1100watt CRUNCH amp 1000watt Kicker 12in sub Battery relocated to trunk Aristo door sills Exterior: BN sports full body kit Voltex type-II wing Toyota visors Toyota chrome door handles Depo LED taillights Serial nine rear quarter panels Custom hibino style fenders TRD front grill Custom purple amethyst pearl with gold flakes Wheels: SSR Agle Minerva 19x11-14 6inch lip 235/35/19 Advan Neovas AD08 19x12-39 7inch lip 265/30/19 Triangle TR968 Gold inner barrels ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() My asking Price is $32,000 Price is only negotiable when it's serious inquires only, everything listed is sold as is.
"if sparks don't fly your rides to high" Last edited by Slide_ways14; 03-17-2016 at 06:29 PM.. |
bump glws.....
Www.PowerAutosports.com Last edited by 95_S14; 07-21-2015 at 05:03 AM.. |
#14 |
![]() Join Date: Nov 2011
![]() Feedback Score: 10 reviews
one of the best GS i've ever seen
Intangible Visionary: Multimedia Production |
Tags |
aristo, drift, gs300, lexus, track |
