08-22-2006, 08:38 AM | #1 |
misfiring why?????
my car is zenki s14, i have a s15 motor/turbo, s14 ECU, z32 MAFs, 480cc injectors, walbro fuel pump, S-AFC 2, profec bspec2, 3inch turbo back, etc.
i had my car dyno tuned yesterday and the results were very poor. something is wrong. the fuel curve and boost curve are quite steady and not abnormal at all. The timing is set and was double checked. The plugs are gapped correctly and were brand new. you can hear the misfiring. theres alot of hesitation when u first step on the throttle too. at 13psi, the car put down 150hp and 140lbs of torque. thats way too low for my setup, the guys showed me charts for a red top with about the same modifications as me and it made 220hp at the wheel. so s15 motor should put down 250 theoretically... not 150, right? we are baffled. anyone have any ideas? |
08-24-2006, 02:38 AM | #2 |
Why dyno it when you know there is hesitation... kinda a waste of money bro.... Secondly, I wouldn't care about fuel curve and boost curve... that is useless... You are at a dyno center, look at the AFR and see what is going on... that will tell you a lot.... Secondly on the tune, is it running any timing advance? Thirdly, check your CAS and see if it is still good.... Fourthly, Put a timing light on it at 2000rpm and see if it is steady or jumpy.....
08-24-2006, 06:15 AM | #3 |
AFR is 11 across the band according to the wideband. timing was 15 and we advanced it to 18 or 19 to see if made a difference.. idle get a bit steadier and smoother but under boost it was still missing and there was no power there. another note, i pulled the plugs out and they were all white.. the wideband says rich and the plugs say lean. how can that happen?
08-24-2006, 01:25 PM | #4 |
Hmmm that isn't good.... Did you ever check your compression, but if you have access.... do a leak down test which is better.... Secondly an S14 SR ECU or S14KA ecu, secondly you have a S15 motorset, I think there are differences in the ECU as well.....
08-24-2006, 01:56 PM | #5 |
s14 SR ECU.... since i originally bought a s14 front clip but the motor had a bad head so i just put a s15 long block/turbo in basically. all the wiring is still from the s14. are the sensors on the motor different at all? i was under the impression that the s15 and s14 motors were identical and just the turbo was different.
