03-23-2015, 03:42 PM | #1 |
Another z32 brake swap question
Anybody know if you can get away without using the z32 rear brake shoe set up for a parking brake?
I snagged a set of calipers and didn't grab the knuckle/hub/etc. because they were all busted up. Are there other ways of running an e-brake with the z32 rear brakes , similar to the stock 240sx brake set up, without running a hydraulic hand brake to the calipers? I know I need the z32 lines but I'm mainly talking about actually making it clamp down without the shoe assembly. Haven't been able to find the answers i've been looking for. -Steve |
03-23-2015, 03:51 PM | #2 |
You can splice z32 rear part of ebrake cables to the 240 front portions. Not sure if this is what youre asking
Or buy an r33 cable
MRP Manufacturing |
03-23-2015, 03:52 PM | #3 |
The z32 e brake is a shoe assembly, I don't believe it has anything to do with the caliper. I don't have the shoe assembly. I'm just wondering what the other options are- if there are any.
03-23-2015, 04:13 PM | #4 |
only way would be to use a Line lock for the rear calipers.
you cannot use a S-chassis Ebrake cable on the rear Z32 calipers
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
03-23-2015, 04:16 PM | #5 |
I know I cant use the s chassis cables. I'm wondering if I can get away without using the drum brake from the z32. But from the looks of it, I can't get around it without a hydro
03-23-2015, 05:43 PM | #6 |
You can use rear Z32 brakes without the parking brake drum assembly.
You will not have a parking brake. Utilizing the main hydraulic brake system to function as a parking brake is not reccomended. In order to have a parking brake, use Z32 parking brake drum assembly and R33 cables.
03-23-2015, 05:48 PM | #7 |
That's what I figured. running a hydro brake into the rear brake lines would work too, no? Or is that sketchy as fuck? I've seen a good amount of DIYs doing it that way without any issues
03-23-2015, 06:15 PM | #9 |
I mean in theory, if hydros lock the wheels consistently for drifting, I would assume it'd lock harder than the factory brake cables......... or am I way off? Especially considering z32 brakes are larger than the factory s13 brakes
03-24-2015, 11:03 PM | #10 |
Your right, but overtime the hydraulic system can loose pressure. That's not safe for parking without being in gear, and or wheels pointed incorrectly on hills.
Get a dual caliper bracket, mount the stockers and your z32's. you might have to modify the pads or find bigger cable driven rear caliper. Or just source the ebrake essembly from a z32 etc. From a Highly Tuned Note 4.5!!!
03-25-2015, 06:53 AM | #12 |
Hey Snoop long time brother!
Steve- First and foremost, I'm all about helping people get their cars to STOP and HANDLE before adding power & killing themselves and others around lol... To employ the KISS concept is a beautiful thing. Easiest, most asspain-free way to go is get: 1. A set of Z32/R32/R33 rear calipers 2. A set of Z32 rear ebrakes: http://www.ebay.com/itm/300ZX-Z32-TT...5c9c4d&vxp=mtr 3. A set of Z32 rear rotors 4. Whichever set of Ebrake cables fits your application: http://www.frsport.com/index.php?tar...q=ebrake+cable 5. A set of ebrake cable adapter brackets... You can also make them with a couple small pieces of metal and a drill/dremel. Mike
Tags |
240sx, brake, s13, swap, z32 |
