FS/FT: 1991 Toyota Cressida 2jz Single Turbo
Contact Info:
(347) 915-4039 text or call Year: 1991 Make: Toyota Model: Cressida Color: Black Mileage: 152,xxx Transmission: Manual Price: $4000 Engine 2jzge engine with stock hg and harness out of a 1st Gen gs300 with brand new valve cover gaskets, seals, brand new clutch fan (from a ls400), with the EGR removed. Brand new radiator SS power steering line XM 91-92 engine brackets Turbo setup T67 turbo kit for a 2jzgte from driftmotion.com which includes: 3in downpipe, 40mm 4 bolt hks style wastegate (11psi spring), t67 turbo of course, 4in intake pipe with filter. 2jzge Ebay turbo exhaust manifold -10an oil drain -3 oil feed with -4 adapter Coilpacks and Ignitor from a 2000 Lexus gs300 1jz/2jz Map sensor 440 injectors and resistor pack from a Mk3 Turbo Toyota Supra 2jzgte Auto Ecu and IAT AEM wideband and Greddy Boost gauge Drivetrain W58 (non-turbo) transmission out of a '89 Supra along with driveshaft, pedals, and slave and master cylinders 2jz bellhousing and flywheel ARP flywheel and pressure plate bolts XTD 6 puck clutch disc and pressure plate SS clutch line Suspension JIC front coilovers from a JZX81 (Toyota Chaser) S13 swaybar links New Driver side RLCA and axle S13 Cusco Rear coilovers Interior Grey Cloth Interior JDM Mk4 Supra 3-spoke steering wheel Gauge Installation kit to replace clock Bad: Rust on passenger fender. Rear Bumper skin is rotted also. It needs an exhaust manifold gasket which I have. Clutch needs to be re-bled and needs brakes. Trades I may be interested in include E39 BMWs (wagons welcomed), E46 BMWs, E36 M3s, and E30s. Might be interested in other cars but those are at the top of the list. All trades must have 3 pedals (manual) and include cash depending on condition and etc. ![]() ![]() ![]() ![]() ![]() ![]() Last edited by BkCressida1718; 04-18-2014 at 07:35 PM.. |
#23 |
the car runs fine even with the boost leak. i daily drove it for a month when i had it temporary registered. The only reason I'm not driving it is because its not registered.
Tags |
2jz, cressida, trade |
