![]() Join Date: Jul 2005
Chat about pros and cons of engines (sr 2j ls mainly but any engine)
sr pros:
30-33mpg at 2800lbs easy to work on good mostly stock around 400rwhp add pros now.... srcons: first and second are always kind of desperate and more power makes the trans potentially suffer disaster as clutches get more "grabby" 500rwhp+ six speed version is slightly unreliable w/ circlip automatic is not really an option limited qty getting expensive 2j pros: legendary 500-800rwhp stock block auto version is acceptable will work in heavy cars 2j cons: expensive (turbo versions w/ low compression and piston oil squirts) I heard its heavy max mpg is 25-? (anybody have data @ 3000lbs?) auto version is dangerous (no torque management has resulted with crashes). ls V8 pros: some cheap iron blocks are almost free and do 500-600rwhp with a valvespring and water injection turbo the lighter, aluminum version supports even more 800rwhp and holds some kinda records (L33) still cheaper than a 2J and probably weighs less ("the new/next 2JZ") Auto includes torque management factory for auto daily driver (ex. rain) ls cons: the light ones are expensive the cheap ones are heavy the best auto transmission 4l80e is so heavy inside it limits economy, at 3000lbs it may be low as 25mpg, depends on gearing 8 spark plugs now, can you reach them all? Etc.... Ok now add all the ones I missed or fix the sentences so they are true (and then vote on a best engine based on pros and cons) |
#2 | |
for example
link to something about 2jz weight https://www.supraforums.com/forum/sh...=1#post8873934 Quote:
because i have to go, i dont have time for this or punctuation etc... but this will be useful as currently the info is split into multiple threads (for example LS sticky, 2J sticky, etc) Just in a couple posts (so its only 1 page or less) Ill edit to take up more space when I see whatever is missing later months from now if you have time and bored |
I feel a storm brewing....but I like it. Great start to a thread for a very annoyingly asked question on here. Sub’d.
Dont be a pussy...Leave your name |
![]() Join Date: Jan 2009
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
"30-33mpg"
No. Not consistently. I daily'd a stock notchtop that ran the definition of perfectly for 5 years and while I got 30-31 a few times, it's only during sustained driving at 65mph or less. Driving at a normal interstate speed(ie 70+, realistically moving with traffic is at least 78) I got 25mpg at best. City was 20-22, less if there was a significant amount of stop and go. I'd be all for this thread but truth be told, your head is stuck so far up your own ass hole it isn't even worth it.
Meh. VET, and get weight, the awesome flowing head and 30mpg. All said and done you'd be in it for the same as a 2J, but with less packaging headache, heat, and more flexibility.
The head is the key to the SR. Personally I would put the VET against the LS or 2J for a legitimate comparison |
#8 | |||
Would you run the VET or JZ on pump 93 and expect long term reliability? I would say probably not. Us LS folks regularly make reliable power on pump 93. So for those reading this, also consider your fuel budget.
#9 | |
350 WHP, unopened SR20DE on a 140K miles 9.5:1 $200 junkyard USDM engine. So yeah, reliable as hell. 2 years of track days (6-8 per season). Kept rev limit @ 7K and went to town. Car weight 2383 lbs soaking wet. This was on my Sentra SE-R. So yeah, a properly tuned VET twill last @ 380 WHP no problem. R comps on any LS is a minimum of a Accusump. Cost of entry is $$ for all three engine options. |
#10 | |
![]() Join Date: Nov 2005
2. Agreed, but: this is the problem I see with threads like this in general. There's good info, but the demands on the engine/chassis/fuel system/etc keep getting raised and by the end of the thread, it seems everyone needs a drysump and elaborate cooling system to be reliable. There needs to be a lot of clarification on "what" and "when" things need to be done if we're going to get into the topic of modifying oil sumps/drainback/coolant swirl pots/oil coolers/etc. I'll add a list of pros and cons for VG engines (SOHC and DOHC) tonight. It's only fitting since I'm swapping one.
#11 | |||
This post from a gentleman at RPM Engines highlights LS cylinder wall distortion quite well. https://www.instagram.com/p/BjYS0Gigk9K/
People always state, " oh you can get a junkyard LS for pennies" blah blah blah. That is not what costs money. It is everything else associated with putting a LS into any car. One still has to buy headers, swap kit, clutch, driveshaft, electronics, oil pan, accessory kit blah blah blah. The costs add up exponentially........and that is if one is buying used.
And it's funny; the argument for getting a cheap junkyard LS is "tarrblooowww!" When any comparisons crops up in regards to LS owners . That should not be top priority of anything but a drag engine and is at the bottom of the list for 95% of the LS swap vehicles. It surely is an additional exponential cost if using reliable components and not shopping on eBay. Last edited by RalliartRsX; 11-26-2018 at 07:55 AM.. |
![]() Join Date: Mar 2015
Are we just gonna ignore the fact by far the best power for budget is built KA-T??? Just a mild built block can take mid 500s-600 which is more than enough. All engines from LS to SR to JZ all basically cost the same as far as good fast mods. Having decent manifold, top feed injectors, switching to e85, bigger fuel pump, spark standalone, trans swap, etc Most of us here arent making more than north of 500 for the average schassis. Anymore power and you're either full straight line racing or competing in pro am/tracking.
Its seems to me like this thread is more of humble brag for the LS instead of people saying why they like certain engines such as feel in the car, parts availability, community for the engine, cost, street/track potential, having AC, and so on. Tbh Im for KA, I made 467whp/462tq stupid easy and its a daily on e85 with AC I get like maybe 12-14mpg with mix driving. Havent taken it to the track yet but building the motor myself, cost of everything with good parts it was fairly easy. I kinda wanted to do a swap but just getting the engine in the car for the amount of money I put in the KA I'd be sitting at what? Max 300-350whp on 5.3 iron block, stock 2jz or stock SR20 with bolt ons? If I had to do another engine it be in another chassis. Either a SR20VET grip build shooting for bare minimum 550 whp or a reliable drift car with a stock 2jz with some bolt ons making at most 400whp Last edited by R3b; 11-26-2018 at 07:50 PM.. |
#17 | |
Bruh, we all know it's closer to 50lbs if we're talking aluminum LS, and probably 30-40lbs if you sleeve the SR. Stop kidding yourself.
#18 | |
![]() I love KA'Ts, but I've never built one before. Could you elaborate a bit on this? I'm really interested.
"Simplicity is the key to brilliance." - Bruce Lee |
#19 | |
To fix this, you simply drill the threads out of the block, and tap them for an M11 sized stud. Then you can use Evo 9 (IIRC) ARP 625+ headstuds and have much better clamp load. You must also drill the holes in the head bigger so there's no binding or oiling issues. The hardcore guys drill them out and tap for M12, where you can use a VG30DE or RB26 stud, which come in ARP2000 or 625+. You're not going to need any more serious of a stud than this. I'm not sure if it's the same with the M11, but with the M12 studs, you actually have to bore the openings in the head where you access the nut, as this becomes too small for the required socket. If you do these, make sure that you get the block torque plate honed with the studs at torque afterwards. You'd be amazed at how much the higher clamp load distorts the bore. I believe JWT hones with a torque plate and bellhousing bolted to the block. These upgrades, combined with DLC VQ35 cam buckets, means you can run big cams and big power, and have a pretty bulletproof package. KA's are cool.
#20 |
![]() Join Date: Nov 2006
I've haven't been around for years, but there is a whole new world of support for the KA. For me personally if there was this much aftermarket support 10-12 years ago I probably would have just built a KA-T.
#21 |
SOHC VG33E:
Pros: 1. Dirt cheap and immensely plentiful. They came in Xterras, Frontiers, Quests, Pathfinders, and Mercury Villagers. 2. Can handle 500wtq on the factory longblock. You don't even need headstuds 3. 3.3 liters means torque! 4. V6 format means good weight distribution 5. Relatively light ~380lbs 6. Compact 7. Bolts to Z31 turbo trans (30A), or Z32 trans (30A) with a flywheel adapter. 8. Legendary cam grinder Ed Iskenderian will regrind your cams for $150 9. Z32TT oil pump can be mounted with VG30DE crankshaft 10. Equal length exhaust manifolds and it sounds like a JZ and a longtube V8 are both in your engine bay screaming to be let out. 11. IMSA winning heritage 12. A ton of clutch options Cons: 1. Needs cams and boost to make power 2. Oiling system is underwhelming and needs modification for track use 3. Pulling one from a commuter car means it's probably been treated poorly 4. Two valve heads don't flow that well 5. Factory manifolds sound like a tractor 6. Distributor can either be great or finicky 7. Fabrication required for swap 8. Comparatively weak aftermarket support VG30DE(TT) Pros: 1. IMSA championship winning heritage 2. VG30DETT oil pump is the bees knees 3. Heads flow quite well 4. V6 package means good weight distribution 5. Equal length manifolds and it sounds like an JZ with an attitude problem 6. Makes Hella torque and power 7. Coil on plug factory 8. Factory transmission is pretty strong with lots of clutch options 9. Strong aftermarket support 10. Hydraulic lifters Cons: 1. Large and relatively heavy ~450 lbs IIRC 2. Four cams = $$$ for aftermarket 3. Oiling system is underwhelming 4. Factory turbos won't fit in s-chassis unless you use a Z32 crossmember and steering rack 5. Complex if you don't make it simple 6. Fabrication required for swap 7. Somewhat rare, only coming in the Z32 and J30 stateside. 8. Hydraulic lifters probably need cleaned and rebuilt
#23 |
I'm posting these links here because they give a very good idea of the pros and cons of each engine, and they save someone from having to type out a book.
RB: 1/2JZ:
#24 |
Strictly longevity. Tuned it myself and it was my first tuned turbo car, so a reliable engine is much more imperative than outright dyno numbers and turning it all into a hunking pile of metal.
Thing was a freckling riot and chased down many a C5 and C6 Vettes. But, trackday, so take that with a grain of salt considering the varying levels of driver ability. But, it did do consistent 130-135 MPH consistent down Summit Point main straight so yeah, there's that lol |
#25 |
AFC #1
![]() Join Date: Oct 2003
My engine builder only uses a TQ plate and I don't know of any place that has been open more than 10yrs that doesn't. If they don't want to, it's because they are cheap fucks that don't want to buy one. It's not a hard task.
#26 | ||
My intent with my post was to address the DIY'ers who might just slap studs in there and call it good.
#27 |
AFC #1
I would never stud anything(Heads, Mains, Rods) without tq loading and making sure everything is still round and hone as necessary.
#28 |
Holy shit. Man, development for the KA lately has been so cool to see. Thanks for explaining, guys. Who do we owe thanks for these headstub/timesert discoveries for the KA? Did this come from Tomei or some KA-T community diehard?
#29 | ||
http://dsportmag.com/the-tech/how-to...of-any-engine/ http://www.ka-t.org/forums/viewtopic.php |
#30 | |
