First of you will need:
Electric speedo replacement
Tools (duh)
And some time
First start by unscrewing the steering wheel plastic cover and any other various trim pieces. Once you get the speedo out (will be held by 3 screws) mine didn't have them because weight reduction. Pull your speedo out.
Now that it's out make sure you remember the plug locations and were the ground was.
Next you will need to unclip the plastic cover that is holding both halfs of the speedo.
![](http://uploads.tapatalk-cdn.com/20160501/ce2f807c27e9ee2f7da9836602a55008.jpg)
They will look like that there are 8.
Once you pull them apart,look for the two screws holding the electric speedo
![](http://uploads.tapatalk-cdn.com/20160501/9f3c5e8b64a5de79b29b4c68fa890533.jpg)
One on each side.
Them flip it over and unplug the clip.(may be hard)
![](http://uploads.tapatalk-cdn.com/20160501/f5caaedb90e1ea92722b4f479d0e82c0.jpg)
Once you unplug it disconnect the ground wire coming from the electric speedo.
Next pull the unite. Now just reverse the steps. If done correctly it would work.
Sent from my HTC Desire 520 using Tapatalk
