Works Engineering Adjustable Cam Gears
![]() Each gear is adjustable in 1° increments to a maximum +/- 10°. Our engraved timing marks are accurate to within 1 minute of degree! With the simple design our gears end up being lighter than the stock gears they replace. Our tooth profile matches the OEM spec exactly for each gear we make. The outer cog section of our gears is black hard-anodized, to prevent on/wear from the timing belt. We use black hard coat because of the great contrast it gives against our engraved timing marks. The 5-bolt locking pattern is plenty secure and we use only stainless steel hardware to ensure durability. This design provides a lifetime of worry-free adjustment. Machining for optimum component fit is critical with adjustable cam gears. Any free play between the inner and the outer sections will cause the hardware to come loose no matter how much is tightened. Our extra care in the machining process guarantees you our gears will not come loose when you follow the torque specifications in our instructions. Currently in Stock ($200CAD per set) 2JZ *B-Series *RB20\25\26 *SR20 *4AGE * Please allow an extra few days for shipping. Items are located at warehouse location. PM or Email for shipping quotes.
Works Engineering - Canada For Inquiries please Email or PM Email: WorksEngineeringCanada[a t]gmail.com PM: WorksCanada |
Tags |
2jz, rb20, rb25, rb26, sr20 |
