Old 02-25-2009, 02:05 PM   #1
schizorazgriz
schizorazgriz is an unknown quantity at this point
wont rev past 3k, not MAF problem
So my S14 sr20det (s13 chassis) wont go past 3k rpm in any gear including neutral. This would normally scream MAF problem but when i unplugged my MAF at idle the car idle changed and then died so there is nothing wrong with my MAF sensor. Is there anything else that i could check that might be the problem? BTW for those of you who are wondering the MAF is a stock s14 sr20det MAF
schizorazgriz is offline   Reply With Quote
Old 02-25-2009, 02:12 PM   #2
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
Try unplugging the maf and then starting the car and see if it runs.
Then plug everything back in and check the ecu for codes.
lok is offline   Reply With Quote
Old 02-25-2009, 02:23 PM   #3
discosteak
discosteak's Avatar
discosteak is an unknown quantity at this point
yeah its the MAF dawg
discosteak is offline   Reply With Quote
Old 02-25-2009, 04:37 PM   #4
schizorazgriz
but if i unplug my maf while the car is on it dies... doesnt that mean there is nothing wrong with it?
i heard that the ecu has different modes it can be in. could it just not be in the right mode for driving? if so how do i change it and how do i check the engine codes. all i see is one little ass screw and no leds
Old 02-25-2009, 04:40 PM   #5
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
Your car should run fine with the MAFS unplugged, but will have a 2500-3000 rpm rev limit.
Try a known good MAFS and report back. Or check for codes like previous people said. I know I had a bad MAFS once and no codes showed up.
Chernobyl is offline   Reply With Quote
Old 02-25-2009, 05:14 PM   #6
schizorazgriz
[quote=Chernobyl;2659945]Your car should run fine with the MAFS unplugged, but will have a 2500-3000 rpm rev limit.
Ok so what does it mean if my car dies when i unplug the mafs? does that mean that theres something else wrong with it?
Old 02-25-2009, 07:48 PM   #7
lok
lok's Avatar
sometimes it will die when you unplug the maf.
that is why i said try and start it with it unplugged. it will put the car in limp mode.
have you hooked up your consult wire?
Old 02-26-2009, 02:10 AM   #8
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
ding ding ding! WINNAR
I dont know how people dont live without at least having a consult cable and Nissan datascan.....
4x4le is offline   Reply With Quote
Old 09-03-2012, 10:14 PM   #9
4x4le
4x4le's Avatar
Guys, get a consult cable and nissan datascan or have fun throwing parts at your car and asking the same question over and over again on zilvia.
If its not the maf it could be practically anything else. Youll save money the first time being able to figure out whats wrong. From then on youll also save money being able to get the right part the first time.
Old 02-26-2009, 02:19 AM   #10
drifter_for_life06
drifter_for_life06's Avatar
drifter_for_life06 is making a name for him/her selfdrifter_for_life06 is making a name for him/her self
Send a message via AIM to drifter_for_life06 Send a message via Yahoo to drifter_for_life06
maf seems shot as previously stated....AAP might be able to read your codes for you
RPS13: +.020" 2871r 264's AEM EMS
http://enjukuracing.com/#_l_4s
drifter_for_life06 is offline   Reply With Quote
Old 02-26-2009, 05:11 AM   #11
Jus Skott
Jus Skott's Avatar
Jus Skott can only hope to improveJus Skott can only hope to improve
Send a message via AIM to Jus Skott
might be cause i literally just woke up like 5 minutes ago. but i thought a bad TPS might cause the same thing.
~skott "mornings suck" B
Looking for yard parts, PM me.
Jus Skott is offline   Reply With Quote
Old 02-26-2009, 11:08 AM   #12
Z33dori
Z33dori's Avatar
usually the maf
my tps went bad it would just buck like a mo-fo
but when m maf went bad it wouldn't rev past 3k or so
Old 02-26-2009, 05:54 PM   #13
drifter_for_life06
if the TPS goes bad I would think it should still go past 3k, just buck and carry on and do it slowly...? maybe im wrong...?
Old 02-26-2009, 07:38 PM   #14
Autobacs
Autobacs is an unknown quantity at this point
If your knock sensor is bad, it will do the something similar.
Autobacs is offline   Reply With Quote
Old 02-27-2009, 01:51 PM   #15
schizorazgriz
So we got a possibility of a bad MAF sensor, TPS sensor, and knock sensor.....
more symptoms. turbo will spool but no boost for that few hundred rpm before it tops at 3k. virtually NO throttle response. when im sitting at a stop light and hit the gas it sits for about ten seconds before stumbling up the rpm ladder super super slow.
Old 02-28-2009, 05:04 PM   #16
d-magic
d-magic is an unknown quantity at this point
Another possibility would be bad ECU. Do you have check engine light?
d-magic is offline   Reply With Quote
Old 03-01-2009, 07:58 PM   #17
tep3
tep3 is an unknown quantity at this point
the same thing happend to my car check ur intercooler piping and couplers.
tep3 is offline   Reply With Quote
Old 03-01-2009, 11:37 PM   #18
schizorazgriz
OK so i fixed the throttle response problem. My fuel pressure was extrmely high and it wa flooding like a mo-fo. fixed that but my rpm will only go up to a little over 3k like 3300. When im in neutral however it will go up to 3k, drop, go up to 3500, drop, and so on and so forth. This happens while my foot is on the gas and im not letting off the throttle at all. I hope that makes sense. is the main cause still looking like the MAF sensor? I noticed that their might be a connection problem with my pcm valve.... could this maybe be it?
Old 03-02-2009, 07:02 AM   #19
910noskillz
910noskillz's Avatar
910noskillz is an unknown quantity at this point
still seems like the maf, i would find someone that you could swap with.....kinda sounds similar to a boost leak also
910noskillz is offline   Reply With Quote
Old 05-04-2011, 09:04 PM   #20
namfbroh
namfbroh is an unknown quantity at this point
I hate to bump an old thread, but I'm having the exact same problem. I was sure it was the maf because the ECU was throwing code 12 - Faulty Air flow meter. Replaced it with a known working MAFS, and it still does this. It runs extremely rich, and it won't rev past 3k. Any ideas what the problem could be? I'm going to check the wiring to the MAFS, but I'm beside myself with what it could be.
namfbroh is offline   Reply With Quote
Old 05-04-2011, 09:31 PM   #21
Om1kron
Om1kron's Avatar
Take the maf sensor out of the housing and clean it make sure the diodes don't have a layer of dirt on them. Still doesn't mean it hasn't shit the bed.
now when you say it wont rev past 3k, does that mean under a load or like sitting in neutral you cannot rev it over 3k?
Wayne Edwards
https://om1kron.blogspot.com
Old 07-13-2011, 06:21 PM   #22
OoAtreyuloO
OoAtreyuloO's Avatar
OoAtreyuloO is an unknown quantity at this point
old thread bump same fuking issue here =[
OoAtreyuloO is offline   Reply With Quote
Old 07-13-2011, 06:32 PM   #23
spoolin405
spoolin405's Avatar
spoolin405 is an unknown quantity at this point
its your MAF. borrow one of your friends or something. If its not that maybe its your ecu?? or wiring?
spoolin405 is offline   Reply With Quote
Old 07-13-2011, 09:46 PM   #24
HAWAII
Trader Rating: (24)
HAWAII is an unknown quantity at this point
Feedback Score: 24 reviews
could be your piping also. might have a leak
HAWAII is offline   Reply With Quote
Old 07-13-2011, 09:50 PM   #25
Swifty
Swifty's Avatar
Trader Rating: (29)
Swifty is an unknown quantity at this point
Feedback Score: 29 reviews
Ever try changing your fuel pump?
Swifty is offline   Reply With Quote
Old 07-13-2011, 09:52 PM   #26
thizzen4
Trader Rating: (22)
thizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymore
Feedback Score: 22 reviews
check ur tps sensor mine did the sammeeeee thinggg
thizzen4 is offline   Reply With Quote
Old 07-13-2011, 09:54 PM   #27
bookoo
bookoo's Avatar
bookoo is an unknown quantity at this point
More than likely, it's a wiring issue, then maf, then tps, then fuel.
bookoo is offline   Reply With Quote
Old 07-25-2012, 02:32 PM   #28
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i am bumping this back because it seems theres no straight answer to fix this issue. i am having the same problem. instead of opening another thread ill just bump it.
Old 09-03-2012, 09:11 PM   #29
h2v7
h2v7 is an unknown quantity at this point
PLEASE help bump
my car runs fine but after ten more or so of driving it wont let me rev past 3k
turn car off and back on and its fine just for a few minutes then wont rev past 3k again.
i have tried a few different MAFS and it does not change a thing.
h2v7 is offline   Reply With Quote
Old 09-21-2012, 11:41 PM   #30
speedys
speedys is an unknown quantity at this point
my sr20det
im not sure what is going on with my car, while driving my car doesnt let me go pass 3-4000 rpm, and when im about to stop the car almost turns off and idles back to 1,000 rpm.
any ideas on what it can be.
i tried unplugging the maf while the car was on to see if it would turn off , and it did, so im not sure what it can be.
speedys is offline   Reply With Quote
maf, problem, s14, sr20det
