07-28-2010, 08:40 PM | #1 |
Trader Rating: (72)
Feedback Score: 72 reviews
s14 air bag light?
oky so iv googled alot about it,
heres the problem i did a ka swap a couple of weeks ago and when i started the car the air bag lights stays on. i have no clue what it is. anyhelp? |
07-29-2010, 09:05 AM | #5 |
Try doing this and see if that takes care of the problem
I had to reset my airbag light after removing the steering wheel / and airbag - so airbag/sensors/wiring was and is in working order. Since your airbag light came on without you doing anything I would recommend having it checked. Got this from the nicoclub: "First of all, while this can be attributable to a bad air bag sensor, it's best to run this past a dealer first.If you're certain it's not an airbag issue, and you simply want to reset the light (after servicing the airbags or dash)... Open driver door Get in Shut door Turn ignition to the on position (all the way, but not to start car) Open door Reach down with your left hand Press the door ajar sensor button thing (7) times Shut door Start your car..... This should reset the airbag lamp." It took me a few tries but I got it. I tried doing the steps slowly and it didn't seem. The last try I did it fast and it worked. |
07-29-2010, 10:47 AM | #6 | |
07-29-2010, 11:03 AM | #7 | |
07-29-2010, 11:36 AM | #8 |
Ill have to do that today i guess, also do you know more exactly where the sensors are located? some people were telling me it might be the harness itself too wich is in the center console area near the back seats is that correct?
07-29-2010, 02:00 PM | #9 |
Yes it is in the center console area. Also check the plug that plugs in the air bag in the steering wheel. By doing that test you should be able to figure out whats causing your light to come on.
07-29-2010, 03:00 PM | #11 |
nissanracer29 thank you for all the help ill be sure to check tonight but if i remember correctly mine doesn't blink it just stays on, s14j sorry for the thread jack lol just thought we can both be helped out with this issue lol
08-09-2010, 01:25 PM | #12 | |
Tried checking all the plugs & seem to be fine now come to find out my car was originally auto (could this be the reason why the airbag light stays on), could that be an issue all? this is also what i found on my center console area. correct me if im wrong but the plug im pointing at is that my park neutral plug that connects to the auto shifter & the second pic is part of the auto shifter as well????????? |
08-22-2010, 02:19 PM | #13 | |
08-23-2010, 12:27 PM | #14 |
thankz for the info ill have to rip that thing outta there then, cars got a few issues to be worked out at the moment & that damn air bag light is one of them. |
08-23-2010, 10:25 PM | #22 |
Trader Rating: (72)
mines still stays on
im sick of seeing it im about to pull out the cluster to take off the bulb! help! its on constant no blinking what so ever need help ^thanks for taking over my thread! have u tried resting it? |
08-24-2010, 10:58 AM | #23 |
Sorry we seem to have the same issue & mine isnt resetable either & it just stays on & doesnt blink at all either but to be honest I hope mine shuts off once i get the correct wire harness & ECU seeing as since my car was auto previously before i bought it. |
08-24-2010, 01:01 PM | #24 | |
Trader Rating: (72)
really so was mines but befor it dint to it onces i did the second ka swap it came up maybe i hit something still wondering |
08-31-2010, 04:28 PM | #25 | |
Damn thats crazy, your issue is probably a minor one compared to mine lolz FML still havent taken care of it. |
10-15-2010, 02:46 AM | #26 |
Trader Rating: (72)
found it
so i was about to take the bulb out of the cluster but then i decided to check my fuses again
fuse was rust and old changed it and it went away wala! |
01-31-2016, 12:38 PM | #27 |
Air bag light flashing
I installed an nrg hub and steering wheel on my s14. Im trying to get the air bag light to stop flashing and i have tried the method using resistors and the reset method . I really dont want to take off the bulb from the cluster . Has anyone done it a different way? Or what else can i try to do
