Old 05-18-2014, 10:54 PM   #1
spools420a
spools420a's Avatar
spools420a is a well-known jackass
degreased engine now headlights wont come on?
yea so yesterday I decided to change my oil and degrease engine,so after degreasing I sprayed down the motor and let it dry for the day.The next night I go move the car and the front headlight wont turn on?its got HID's what did spraying most likely short out?
spools420a is offline   Reply With Quote
Old 05-18-2014, 10:56 PM   #2
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
If they are cheap than most likely you got water into the electrical piece (cant remember the name of it currently) and thats the issue.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 05-18-2014, 11:06 PM   #3
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
Doh.... that's why it's a good idea to disconnect the battery before spraying the engine bay. Check fuses/relays.
az_240 is offline   Reply With Quote
Old 05-18-2014, 11:28 PM   #4
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
Ballast probably got water inside of it.
Nizzan4u2nv is offline   Reply With Quote
Old 05-18-2014, 11:31 PM   #5
spools420a
spools420a's Avatar
fuses are all good,which relay is it?isnt there two ballists?seems kinda odd both would go out?its 10:30 at night so ima try to get my game plan for tomarrow morn but so far i test lighted known fuses and all are good.
Old 05-18-2014, 11:35 PM   #6
spools420a
spools420a's Avatar
agreed,my negative battery cable terminal has one more pull or so before its over stretched and lose fitting on the battery so I thought I could skip disconnecting like so many times i didnt disconnect before and look where it got me....
Old 05-19-2014, 06:47 AM   #7
spools420a
spools420a's Avatar
so two fuses coming right off the ballast wiring from relay have no power going to them,possable relay blown?
Old 05-19-2014, 09:40 AM   #8
spools420a
spools420a's Avatar
FIXED! was the ballasts relay,swapped it out and was corroded and wet and now with new relay lights are working thanks for the input guys.
Old 05-19-2014, 09:53 AM   #9
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
glad youy got it working with a quick fix
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline   Reply With Quote
Old 05-19-2014, 12:12 PM   #10
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Next time put a plastic bag over sensitive electrical components. Washing your engine bay without proper precautions leads to more problems than solutions.
Old 05-19-2014, 12:14 PM   #11
hellion240sx
can you be specific for him. So he knows for next time. please. thanks.
Old 05-19-2014, 12:24 PM   #12
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
It could be worst, it could have been his starter or alternator. I never ever spray down those 2 or the CAS/distributor area.
CLICK HERE!!!
Old 05-20-2014, 10:18 AM   #13
spools420a
spools420a's Avatar
put a condom over it then electric taped it,doing this should make it water "resistant"c
