Old 01-25-2009, 07:39 PM   #1
S14Cuhh
S14Cuhh's Avatar
S14Cuhh is an unknown quantity at this point
Send a message via AIM to S14Cuhh
CA clutch fan delete. DO's and DON'Ts
..on a kaDE setup. what do you people out there have to say
-definitely gonna run an e-fan but besides that
S14Cuhh is offline   Reply With Quote
Old 01-25-2009, 08:13 PM   #2
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Clutch fan with shroud is the best most efficient set up.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 01-25-2009, 08:15 PM   #3
palmdale_mob
palmdale_mob's Avatar
palmdale_mob is an unknown quantity at this point
^^ Seriously?
palmdale_mob is offline   Reply With Quote
Old 01-25-2009, 08:33 PM   #4
projectRDM
projectRDM's Avatar
Originally Posted by palmdale_mob View Post
^^ Seriously?
Welcome to Earth. Yes. A clutch fan can move more air than any electric fan and with less drag on the engine. A good size electric fan can pull up to 30amps, putting a drain on the alternator and forcing it to work harder. The clutch fan is bolted to the water pump, it's not much more effort to turn the clutch than to just turn the pump alone. With the shroud in place you're directing 100% of the air through the radiator, maximizing it's efficiency too, keeping the coolant that much cooler overall.
That said, a lot of people remove it to gain room or to reduce noise and do fine with electric fans, and as any FWD car owner can attest to an electric fan does the job fine, but it's only because a clutch fan wouldn't work on a transverse layout.
FORMERLY R240NA
Old 01-25-2009, 08:40 PM   #5
!Zar!
!Zar!'s Avatar
Zilvia to the rescue.
projectRDM is 100% right.
Old 01-25-2009, 08:46 PM   #6
palmdale_mob
^^ Good stuff
I thought that w/o the clutch fan its less weight for the belts to spin, therefore more hp
So even if its deleted that makes the alternator work harder for an electric fan so its kind of a lose-lose on the gaining hp aspect?
Old 01-25-2009, 08:52 PM   #7
projectRDM
projectRDM's Avatar
^^ Good stuff
Exactly. You're not gaining anything by just replacing one draw with another one. Take a clutch and fan off and weigh it, it's virtually nothing. Any gains achieved by removing it are so negligible you'd never notice it.
That being said though, I do not run a clutch fan due to fitment issues. But I also have a very nice shroud that I spent a lot of time making and plenty of ducting in front of it so my two electric fans at least still direct 100% of the airflow needed through the radiator. Simply placing one big fan or even a pair on the radiator's core with those little ziptie deals results in the air blowing across the entire core support, above, below, and around the radiator. Remember that when you're driving the air coming through the radiator is pushing against the air you're creating from the fan. Not channeling it correctly leads to a greater loss of directed airflow. That big fan may do wonders when the car is sitting still but without a proper shroud it's not worth much when moving.
FORMERLY R240NA
Old 01-25-2009, 08:59 PM   #8
palmdale_mob
Wow I just learned something, thanks man
Old 01-25-2009, 09:06 PM   #9
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
makes sense but i think i'll stick with my slim-fans and air diversion panel
slow40sx is offline   Reply With Quote
Old 01-25-2009, 09:09 PM   #10
HyperTek
this might give you some ideas to do it right if you do it.
http://zilvia.net/f/tech-talk/233498...ro-gt-fan.html
Make sure you get a fan with a shroud.. Good junkyard fans are ford Taurus 3.8l fan, and pontiac fiero GT... since they both have shrouds and fit the rads pretty good with little to no trimming.
Dont skimp on wiring.. and you should have a good idea of how things work.. so you dont want to be out driving and see your temps skyrocket and not be able to pull over and quickly diagnose why your fan didnt cool etc etc.
Keep it Classy
Old 01-25-2009, 09:10 PM   #11
gyula hlavati
gyula hlavati's Avatar
gyula hlavati is an unknown quantity at this point
Same here.
gyula hlavati is offline   Reply With Quote
Old 01-26-2009, 12:04 AM   #12
juice.def
juice.def's Avatar
juice.def is on a distinguished road
Clutch fan coming through with the clutch....
juice.def is offline   Reply With Quote
Old 01-26-2009, 12:49 AM   #13
!Zar!
!Zar!'s Avatar
Wait...
wut?
Old 01-26-2009, 12:50 AM   #14
khmer1
khmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymorekhmer1 is not welcome here anymore
what year taurus for the people that dont know
khmer1 is offline   Reply With Quote
Old 01-26-2009, 07:46 AM   #15
g6civcx
g6civcx's Avatar
On my V8 I would have preferred to use a clutch fan and shroud, but due to engine placement so far back I couldn't find a clutch fan long enough to fit.
I'm using FAL fans which should only pull 19.5A, but the fans still drive the electronics in my car crazy with noise.
Old 01-26-2009, 08:33 AM   #16
DDSR240
DDSR240's Avatar
DDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond repute
First off I wouldn't think that the wieght of the clutch fan wouldbe what causes the most drag it would most certianly be the air resistance it encounters when its trying move x amount of cfm. then you said that it makes the alternator work harder well couldn't you just get a higher amp alternator out of that pathfinder I think its like a 90 amp. Then all you havee to do is choose wisely on you e fan set-up= low current draw+high cfm electric motors are getting more efficiant every day. Not that I'm bashing clutch fans but e-fans are not that bad.
DDSR240 is offline   Reply With Quote
Old 01-26-2009, 08:40 AM   #17
murda-c
murda-c's Avatar
I pulled my clutch fan off without replacing it with another fan kekekeke.
my clutch was seized and i got tired of it sounding like a ups truck.
doesn't overheat because i don't sit in traffic, i'll replace it before summer though.
Old 01-26-2009, 11:56 AM   #18
projectRDM
projectRDM's Avatar
No one said electric fans are bad. They're fine. They're not as efficient as a clutch fan, simple. A higher output alternator, say even a 110A Quest model will still require more draw as it loads up, and as most Nissan alternators do the gains in amperage are only at higher RPMs, the 90A Zenki SE model outputs the same amperage as the base 80A below 4k RPM. So at idle and cruising speeds a larger alternator isn't doing any better than what you already had.
FORMERLY R240NA
Old 01-26-2009, 04:01 PM   #19
IStop4NoMan
IStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant future
I had dual FAL fans with the DIF dual fan controller and it was drawing a serious amount of power when both fans were running. i had to ditch the miata sized battery i had since 5 seconds of the fans on would drop the voltage below 13Volts. I upgraded to a stronger battery and didnt have the voltage problem.
Eventually i went back to the clutch fan and i cant tell a difference in power, but my average temps are only 140 degrees F. I guess the koyo aluminum rad is overkill with the clutch fan haha.
IStop4NoMan is offline   Reply With Quote
Old 01-26-2009, 07:22 PM   #20
NissanGuy16
NissanGuy16 is an unknown quantity at this point
My s14 has a stock electric fan for the A/C which comes on when the A/C is on or then the motor reaches a certain temperature. The clutch in my belt driven fan seized so I took it off. "UPS truck" LMAO that's exactly what it sounds like. I have no cooling problems with my car and I live an hour away from Myrtle Beach so it gets hot here during the summer.
NissanGuy16 is offline   Reply With Quote
Old 01-26-2009, 07:28 PM   #21
projectRDM
projectRDM's Avatar
We know this. All Schassis cars have an electric fan as a supplement to the clutch fan. On S14s it's a 2speed unit, low speed comes on at 203 degrees, high speed at 212 or when the A/C switch is engaged. No one said you have to run the clutch fan, it's usually fine without it as long as your cooling system is up to par, but it cools better and more efficiently with it installed.
FORMERLY R240NA
Old 01-26-2009, 07:37 PM   #22
Keith_Bergen
Keith_Bergen's Avatar
Keith_Bergen is an unknown quantity at this point
I had to ditch my clutch fan due to the blades cracking and almost ready to break off, so i bought myself an fal dual electric designed for my 240, uses the mounts for the stock a/c electric fan which makes it super easy to install, really cleans up the engine bay, covers the entire rad surface area so there is no bypass of the fans so you get best efficiency, and is also wired through a constant so it cools after the car is turned off, never had a problem with battery draw, and also wired to turn on when a/c is on like the stock electric did. I love it and would never go back to the stock clutch fan
Keith_Bergen is offline   Reply With Quote
Old 01-26-2009, 08:00 PM   #23
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
Sorta off topic...but how do you recommend ducting a push-fan setup? Instead of building ducting around the fan and rad (on a pull setup), would i want to duct as much air from the inlet in my bumper to the front of the rad? (i'm thinking like a sheet metal "tunnel" surrounding the rad).
I know it's not ideal (pushing vs. pulling)....but i have no other choice after stuffing in a straight 6 (at least i haven't found any fans slim enough yet...)
96Turbo is offline   Reply With Quote
Old 01-26-2009, 09:45 PM   #24
projectRDM
projectRDM's Avatar
Juts like you said it, make a tunnel to direct airflow to the fan from the bumper opening. Start with cardboard to get your pieces right then step up to sheetmetal, that way you're only making the cuts once. Use door edge guard on the edges to prevent cutting anything and foam tape to seal it tight.
FORMERLY R240NA
Old 01-26-2009, 09:55 PM   #25
WERDdabuilder
WERDdabuilder's Avatar
will you be at the laugh factory this week?
When the power of love overcomes the love of power, the world will know peace
Old 01-26-2009, 09:59 PM   #26
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
I removed my OEM fan:
1) For more room in the engine bay.
2) Cause I had Altima fans laying around.
3) Cause I don't like sounding like a dump truck when accelerating.
This I didn't know. I thought it was just high temp or A/C. I have to rewire my fans soon anyway, so I think I'm gonna try to take advantage of this.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 01-26-2009, 10:11 PM   #27
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
Same here, I have owned two S13s, neither of which had any kind of fan on them (besides the stock electric fan). I have 100 degree+ summers, and lots of traffic. Pfft, fan schman.
ryguy is offline   Reply With Quote
Old 01-26-2009, 10:32 PM   #28
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
it may not make any difference in stop and go traffic or just normal daily driving, but it is crucial to have your shit setup properly if you are hitting the track.
Old 01-26-2009, 11:15 PM   #29
projectRDM
projectRDM's Avatar
The best way is to use two more relays and leg them off the OE signal from the ECU. That way both fans can be used for both low and high speeds. Fuse the input power to 30A each just like the original circuits.
FORMERLY R240NA
Old 01-26-2009, 11:16 PM   #30
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i have a ford taurus e fan with the shroud. never had the problem.
