Old 11-26-2014, 09:21 AM   #1
laurentj23
laurentj23's Avatar
laurentj23 is an unknown quantity at this point
Q45 diff
Do I have to get 96-01 diff to fit in the s14? I tried searching online about the dimensions but couldn't find anything. What's the different between 04 diff and the earlier model diff? Is the pumpkin different? Final drive ratio?
'Born Ready!',LJ
laurentj23 is offline   Reply With Quote
Old 11-26-2014, 09:28 AM   #2
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
From what I understand the pre 1996 diff will fit in your car as well. The housing is the same but the ratio is different. The pre-96 had a ratio of 3.54 and the post-96 had a ratio of 3.69. I don't know anything about the newer q45 diffs.
Sr22 in the works
slow92 is offline   Reply With Quote
Old 11-26-2014, 09:49 AM   #3
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
90-96: Need larger wheel hubs like the Z32TT, Z32 TT driver side axle, Q45 driver side axle. This has a 3.54 ratio.
97-01: Uses stock stock S14 vlsd equipped axles or J30. 3.69 ratio.
2muchboost is offline   Reply With Quote
Old 11-26-2014, 09:53 AM   #4
ixfxi
ixfxi's Avatar
Location: bangin on my chest Account: BANNED #fucksupreme
ixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfection
Nah, you dont have to.
Just leave it stock and your car will still work.
ixfxi is offline   Reply With Quote
Old 11-26-2014, 09:58 AM   #5
laurentj23
laurentj23's Avatar
Thanks guys.. I'm familiar with info. Still needs to know whet here 04 year diff will fit?
'Born Ready!',LJ
Old 12-10-2014, 10:09 PM   #6
2muchboost
Trader Rating: (33)
Not sure but what ratio are you trying to achieve?
Old 12-11-2014, 08:08 AM   #7
laurentj23
laurentj23's Avatar
3.69/ 3.54 . I just need the ring and pinion. I can pick it up on the 26th or 27th. Ill be down there for vacation
'Born Ready!',LJ
Old 12-11-2014, 08:13 AM   #8
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Swap the guts, your ring you want and call it a day.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 12-11-2014, 08:17 AM   #9
laurentj23
laurentj23's Avatar
Is 04 diff guts and rings interchnagable though? I know the 91-01 does.
'Born Ready!',LJ
Old 12-11-2014, 08:38 AM   #10
5280VertDET
Found this, I think the 04 use the R230, so I am incorrect.
Originally Posted by orion::S14 View Post
They do not fit.
The Q45 uses an R230, identical to the 300ZX TURBO. It does not bolt into the S13/S14 subframe...
IIRC, the M30 uses a weird rear suspension, some trailing arm setup...and has a diff similar to an older Z31 300ZX...the internals may be R200, but the case (or the whole diff) is not a bolt in deal.
If you read this on the 240sx.org page about diffs...that page sucks, lots of errors.
I have fixed the errors, and posted all the other good info for you:
http://www.ka24development.com/vlsd.html
Hope that helps... - Brian
Old 12-11-2014, 11:00 AM   #11
laurentj23
laurentj23's Avatar
Thats what i needed to know. Thanks.
'Born Ready!',LJ
