04-20-2015, 06:56 PM | #1 |
Clean built 95 s14 ka-t fs/ft
Fs/ft Ka-t
Emerald Green 165k mi Please read carefully Issue: calum ecu took a dump so I purchased a rs enthalpy ecu. Car is now up and running. However, when at wide open throttle it seems as if the spark is being blown out. Not sure why but I don't have the time nor money to keep investing. Body: New paint, 2 yrs old. Professional job, extra flake added to stock color. Nice body Engine: 10k mi* Block bore, blueprint Arias 8.8:1 Eagle Rods Clevite Bearings ARP head, main, rod bolts Reman'd head: valve job, surfaced, new seals New oil pump, front cover New timing chain kit EVERY gasket and seal is new* All emissions removed Custom Spearco radiator Custom Spearco intercooler Turbonetics DUO bov (recirc) All custom piping Z32 maf z32 pop charger/filter(needs new filter) TO4B turbonetics turbocharger, 54mm compressor, water cooled 3 in SS straight downpipe, no cat Espilir cat back Turbonetics Evolution wastegate, recirculated JGS engine mounts 52lb/hr injectors Walbro 255 fuel pump No A/C(I have most if not all components ) Nissan quest alternator Newer starter Drivetrain; White bunny special clutch setup: 350z flywheel, 400lb-ft tq full disc 5-10K mi on clutch and new hardware All new clutch hardware: clutch fork, spring, pivot ball, rubber seal, throwout bearing slide, transmission front cover (sleve that throwout bearing rides on, stock one was cast aluminum and broke, new one is cast steel) Stainless clutch line Newer slave cylinder Newer Master cyl Circuit sports short shifter S13 VLSD Suspension/brakes/wheels: Circuit sports coilovers Circuit sports rear upper control arms Circuit sports toe arms Front strut bar Front stock anti-sway bar Gram lights 17x8 front, 17x9 rear BFG tires Z32 front alum. calipers Stainless front lines Interior: Pretty clean, seats and carpet need a shampooing Autometer boost, oil pressure gauges Eugo Wideband Looking to get $6200 obo or trade for a wrx, or a 03/04 tacoma 4 door trd. If your interested please text 9092245853 Last edited by Chrcastro23; 05-03-2015 at 12:41 PM.. |
04-20-2015, 07:19 PM | #3 |
Yea lol.. it's going to be something stupid. Previous owner just told me that this ecu has a battery and if it goes bad it may loose the tune, so I'm going to try and replace it and re upload the tune.
04-20-2015, 08:21 PM | #5 | |
