01-04-2016, 12:19 AM | #1 |
Driveshaft Wont Fit??
I have an sr20 with a j30 diff and ive been using a non abs driveshaft for the year no problem. I recently replaced the trans with a KA trans and installed an ACT clutch kit. For some reason I cant fit my driveshaft back on. It seems to be a bit too long, I don't understand why since the ka trans is the same length.
Ive tried loosening the diff and unbolting the trans subframe. Any input would be appreciated |
01-04-2016, 08:24 PM | #3 |
Trader Rating: (106)
Feedback Score: 106 reviews
Get a hammer and flathead screwdriver and knock the dust shield off the back of the trans. It's the sheetmetal ring that's pressed onto the output housing. You CANNOT run a NON-ABS driveshaft with an ABS diff unless you remove that shield. Your old trans might not have had one already.
01-04-2016, 11:40 PM | #5 | |
01-05-2016, 08:40 AM | #7 |
Ran across this thread and it's great info to have.
This may be a stupid question but if you still have working abs does swapping to a non abs driveshaft affect the abs working correctly? |
01-05-2016, 02:49 PM | #8 | |
Sent from my SM-N910T3 using Tapatalk
