Old 10-01-2010, 04:07 PM   #1
kyleshell
kyleshell's Avatar
kyleshell is an unknown quantity at this point
Exclamation Rear clunking noise, only under acceleration
Ok so I am about to pull every hair out in my head at this point. There is a clunking noise from the rear, towards to back right wheel of my S14. I have coils, RUCA's, toe rods, traction rods that are aftermarket back there. Stock rear brakes.
Ok so here's the problem. When I start off in 1st gear, nothing makes noise. In every gear after that, this clunking noise begins. It only happens when the car is under acceleration, when there is force/pressure being applied. I have gone through several phases of lowering and raising the car. Before I raised it up a little bit, the car was pretty low. And at that height it never made this funky noise. But when I raised it back up to where is sits now, that's when it started. I have checked every link, nothing is rubbing, etc...I don't know what else to frackin do. Someone pleeeeaaaase shed some light on this sitiation!
kyleshell is offline   Reply With Quote
Old 10-01-2010, 10:04 PM   #2
ScrapnSidwayz
ScrapnSidwayz's Avatar
ScrapnSidwayz is an unknown quantity at this point
Does it only clunk when you let on and off the accelerator?
ScrapnSidwayz is offline   Reply With Quote
Old 10-01-2010, 10:09 PM   #3
S14Driftr91
S14Driftr91's Avatar
Trader Rating: (26)
S14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to all
Feedback Score: 26 reviews
could be your subframe bushings
www.allthingsproper.com
S14Driftr91 is offline   Reply With Quote
Old 10-01-2010, 10:10 PM   #4
iLagX
Trader Rating: (40)
iLagX is an unknown quantity at this point
Feedback Score: 40 reviews
Send a message via AIM to iLagX
you got a 2 way lsd?? i fixed my problem. one piece drive shaft and new subframe bushing and NEW GEAR FLUID
PARTING OUT S13/S14 NEED PARTS PM ME!
iLagX is offline   Reply With Quote
Old 10-01-2010, 10:12 PM   #5
MinesRed
MinesRed is an unknown quantity at this point
I almost have the same problem on my s13 but instead of clunking noise
It makes annoying creeking noise at the left rear.
MinesRed is offline   Reply With Quote
Old 10-01-2010, 10:13 PM   #6
MinesRed
****edit*** double post****
Old 10-02-2010, 09:43 AM   #7
kyleshell
kyleshell's Avatar
only when i press the accelerator. from barely pressing it to fully pressing it.
Old 10-02-2010, 09:44 AM   #8
kyleshell
kyleshell's Avatar
I put some SPL collars on there, but the actual bushings may be shot.
Old 10-02-2010, 09:47 AM   #9
kyleshell
kyleshell's Avatar
Well it had an open. Put a vlsd in and then it started making that noise. Thought it could have possibly been a faulty pumpkin, so I put the open back in. Still makes the noise. Maybe the extra length of the vlsd being ABS on my non-ABS car made the driveshaft and something along side it get out of whack.
Old 10-02-2010, 09:51 AM   #10
kyleshell
kyleshell's Avatar
yeah man, its very aggravating to say the least.
Old 10-02-2010, 12:39 PM   #11
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
make sure the bolts from the axle to the diff arent loose! happened to me and i heard a terrible clunking
R@ddy is offline   Reply With Quote
Old 10-02-2010, 03:39 PM   #12
kyleshell
kyleshell's Avatar
Have checked those also
Old 10-02-2010, 04:00 PM   #13
blktopsr20
blktopsr20's Avatar
Trader Rating: (83)
blktopsr20 is an unknown quantity at this point
Feedback Score: 83 reviews
check ur collars, check your axles for any play, check subframe nuts if their tight enough, basically re-tighten (or maybe too tight) all nuts and bolts that you took out initially when swapping aftermarket parts. lastly, check the 4 bolts that holds the hub.
blktopsr20 is offline   Reply With Quote
Old 07-09-2021, 10:10 PM   #14
Mrdabguys13
Mrdabguys13 is an unknown quantity at this point
s13
??PLEASE someone let me know if this was figured out I have the exact same problem and they thought it was the drive shaft but 1 single piece drive shaft later it?s still happening!
Mrdabguys13 is offline   Reply With Quote
