Old 07-10-2015, 01:43 PM   #1
S14kouki805
S14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud of
Cylinder wall imperfection- to sleeve or not to sleeve?
So I'm rebuilding my blacktop SR20 block after melting piston #1.
Cylinder wall took some damage, machine shop bored it out to 87mm and it still has a small imperfection, sort of like a small divot, enough to feel with a finger nail. He described it as about as wide as a dull pencil tip. I'd post a pic but I forgot to take one when I went down there.
Obviously the concern is the rings or lands catching the divot and fucking up my freshly rebuilt engine.
Anyway, he's saying I could roll the dice and run as 87mm pistons, or get the one cylinder sleeved and go 86.5 across.
My last option would be to source a used block which I really don't want to do...
What says the Zilvia community???
S14kouki805 is offline   Reply With Quote
Old 07-10-2015, 02:07 PM   #2
Koukiii
Koukiii is an unknown quantity at this point
Deff get it sleeved. Imagine building the motor and that cylinder takes a shit. You will sleep a lot better at night with a sleeve or another block.
Koukiii is offline   Reply With Quote
Old 07-10-2015, 02:21 PM   #3
ultimateirving
ultimateirving's Avatar
Do it once do it right. Like the guy above me said, you want reliability or short term savings?
Z32 with lq4 swap
Old 07-10-2015, 09:53 PM   #4
cotbu
cotbu's Avatar
I agree with the sleeving, but I would go back to stock bore on all. Unless you already have over bored pistons. Or are planning some monster build
Sent from a Highly Tuned Note 4.5!!!
Old 07-12-2015, 08:51 AM   #5
Arrowking
Arrowking's Avatar
Arrowking is an unknown quantity at this point
I'd go ahead and get it done right. No sense in putting it together just to have it have a ring failure within 100mi.
Of the two remaining options, I'd go ahead and source a used block instead of sleeving one cylinder. Sleeves can reduce the cooling ability of the cooling system so I definitely would get it done on all four or not at all.
Arrowking is offline   Reply With Quote
Old 07-13-2015, 03:03 PM   #6
S14kouki805
Thanks for the responses, at this point I am now considering just buying a used SR20 and parting out what I don't need.
The estimate is about 2g's for a rebuild, I know it will be essentially a new engine but for that price I could get a used block and save a shitload of money.
My concern is rolling the dice on a used engine...any input on this?
Old 07-13-2015, 05:57 PM   #7
cotbu
cotbu's Avatar
They're all used engines, yes even the one you have now!
2g's for a rebuild is nothing as long as you're doing the labor. Shops here charge $1500-$1700 for a tear down/rebuild, not even installation of any new parts.
So this is where you put on your big boi pants or large female panties and make the decision for yourself.
Old 07-13-2015, 06:22 PM   #8
S14kouki805
LMAO- yes you're correct...fuck why does shit have to cost so much!
Old 07-13-2015, 06:38 PM   #9
Arrowking
Arrowking's Avatar
I agree with the other poster, if you can go ahead and swing for the rebuild (better than getting a used motor)! If you mean just a used block and transferring all your stuff to that one then I'd go that route instead of a used shortblock. Heck, I'd even go one step further and get them all sleeved (if I had the cash). My thoughts are, just one sleeved cylinder is an unnecessary complication.
Old 10-06-2015, 12:57 PM   #10
S14kouki805
UPDATE: Went ahead and got the rebuild done with just the one cylinder sleeved, they did an awesome job.
I'm thinking of starting a build thread, stay tuned.
Old 10-07-2015, 08:52 AM   #11
KAT-PWR
KAT-PWR's Avatar
KAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really nice
You only sleeved one?
I'd be curious to see a heat map of an engine with one sleeve, i don't know much about them but im guessing the sleeve is made out of a stronger material with different heat capacity. How does this effect tuning or deviation across cylinders?
*waitsfortalontogivemeanextremelylongwindedexplana tionthatcouldprobablybesummedupinfewerwordsTLDRplz
MRP Manufacturing
KAT-PWR is offline   Reply With Quote
Old 10-07-2015, 11:22 AM   #12
jr_ss
I know a local guy that sleeved one cylinder. The motor cracked the remaining material between cylinders and started using coolant as a result. I think the best option is to sleeve all of them if you have to sleeve one. More money up front, yes, but sleep easier at night knowing it'll be fine.
Old 10-07-2015, 12:24 PM   #13
S14kouki805
The work was done by pretty reputable shop, they suggested just doing the one sleeve.
I could see how it may affect cooling but I doubt it will cause any major issues.
We shall see!
