03-11-2015, 03:19 PM | #1 |
Need tech help with my newly swapped sr20det
Okay guys i desperately need your expertise to help me get this thing running. Here's what i know... its a s13 240sx with a s13 sr20det TYPE X swap. I swapped in the motor and hooked up everything leaving the battery hookup for last. I accidentally hooked up the battery wrong (opposite terminals) and immediately blew up my alt fuse... so i disconnected it quickly ( i did not try and crank the engine while hooked up wrongly). So long story short, I replaced the fuse, the ignitor chip, and the ecu just in case i fried them.
PROBLEM: Engine cranks, gets fuel, gets spark and no start using the 62 ECU Okay new objectives. 1. How can i find out if my harness is a type x harness. I know i have a type x motor(well at least that is what ive been told by a pretty reputable guy). 2. Any instructions on how to repin my 62 ECU to work for a "type x harness" Or is it me rewiring my "blue plug" to be compatible with a 62 ECU. Which way is it? 3. I plugged in my E5 ecu today and i got no spark again so i thought it just might be stuck in diagnostic mode because that mode screw on the ecu is broken. All at the same time i checked for voltage on my CAS and it all read -0.5v... so yeah i dont know what the means lol. So basically I have no working E5 ecu. I dont know if i have a type X harness or not. When i do plug in the 62 ECU i get spark, fuel and it cranks but no fire. EDIT: everything that has changed is highlighted in RED Last edited by regnaleb; 04-02-2015 at 12:28 PM.. |
03-11-2015, 04:22 PM | #3 |
I really dont think "question 2" is a big problem. I was just curious. It should work because its a new body harness and new engine harness. Does it matter if the body harness is from an sohc car or dohc car? or if the ka harness that was made to work for sr was either sohc or dohc?
03-11-2015, 04:51 PM | #4 |
A ka engine harness doesn't work on sr20's.
The chassis harness can be modified to work with the sr20 engine harness regardless if it is for a sohc or dohc chassis. |
03-11-2015, 05:46 PM | #5 |
I understand. But you can use the ka harness and modify it to work with the sr. Im asking if it matters if the ka harness that you modify is dohc or sohc. i never knew you had to modify the chassis harness to work with an sr? im confused now
03-11-2015, 05:46 PM | #6 |
You can test the cas by spinning it with the koeo, (key on engine off,) spin the cas and see if any fuel squirts from the Injectors, the spark plugs will also spark if you have them Hooked up so don't light yourself on fire
Z32 with lq4 swap Desert Street Scene || Dssevents.com |
03-11-2015, 05:52 PM | #7 |
Okay so i have to remove just one injector or all 4? Id have to correct the timing again before i place the cas in right? or just do a full 360 turn and put it back in. Also i know that the injectors are firing so would it be possible the cas still be a problem? My main problem is that im not getting spark. I know i am getting fuel because my spark plugs smell like fuel
03-11-2015, 07:31 PM | #8 |
No, an sr swap does not involve any chassis harness modifications. But as for your question #2, no it does not matter as long as you have the brown and gray plugs wired correctly.
As for #3, not sure but I'd have to assume it does not as I've swapped that around before on my old cars. Have you confirmed the red LED light on the ecu lights up? Otherwise it could be a bad wiring job.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd |
03-11-2015, 08:23 PM | #9 |
For the most part it sounds like timing isnt correct.
Set the engine to tdc, install cas try starting the engine. If you are sure you have a spark problem, pull fuel pump fuse, pull out a coil pack, insert a spark plug, ground the plug and with koeo, spin the cas. If there is no spark you have to check the wiring. If they do spark, you were probably out of time. From a Highly Tuned Note 4.5!!!
03-11-2015, 11:54 PM | #11 |
Yes, I am confident the chip works. i've tested it on an already running sr. Thank you guys for the input. Working on it tomorrow and seeing if anything comes up
03-12-2015, 08:45 AM | #12 | |
pull CAS
make sure you are at top dead center re-install cas after line up the dots i put my CAS 180* out and i though i was missing spark.
03-12-2015, 09:14 AM | #13 |
What I meant was that the plug from the engine harness to the chassis harness has to be modified.
Also, i've never heard of modifying a KA engine harness to work on an SR. |
03-13-2015, 01:13 PM | #14 |
So today i span the CAS while out of the engine (correctly) and there was still no spark. Does this mean the CAS is fried? Remember i accidentally hooked up the battery wrong momentarily and blew the alt fuse. Could it be possible i fried the wiring? i pulled the entire harness out and checked it closely and everything seems to be fine. I am confident the wiring is correct as i had a reputable guy do it.
03-20-2015, 06:00 PM | #15 |
Do you have all the grounds for the engine?
One off the intake next to throttle body to chassis, and behind head to chassis, and I think one more Then you have the coil pack ground wire that goes behind the head |
03-21-2015, 08:54 AM | #16 | |
04-01-2015, 03:01 PM | #17 |
Alright so i rewired the grey plug that plugs the engine harness to the body harness behind the battery. None of the wires matched the first time which is why i think the spark plugs werent sparking. So all of that is done now but still no start. Ive noticed that the headlights dim in and out while cranking but ive checked the grounds and all are doing their job. I also forgot to mention the engine is a type x sr20det blacktop. Any suggestions would be greatly appreciated
04-01-2015, 03:34 PM | #21 | |
04-01-2015, 04:30 PM | #22 |
well i have an e5 ecu but the self diagnostic screw doesnt stop when i turn it... is there a way to bypass this. Would the wrong ecu make my lights dim like that?
I also never seen my check engine light turn on |
04-01-2015, 05:45 PM | #23 | |
The wrong ecu, shouldn't make your lights dim, but I tired starter could. Try jumping the car, and or freshly charged battery? You have to wire up the check engine light for it to work on the dash. The pin location should be in that pinout. From a Highly Tuned Note 4.5!!!
04-01-2015, 06:14 PM | #24 |
should i try soldering one from my 62?
Shit im not good with pins and stuff... ill look up soldering a used thingy any good instructions on how to approach repinning something? |
04-01-2015, 06:14 PM | #25 |
yeah i always jump the car because the batteries completely dead.
Whats The difference in wiring for the type x engines in relation to this link http://www.frsport.com/SR20DET-Swap-...SR20_t_26.html in figure 5a or is there no difference at all? |
04-01-2015, 06:45 PM | #26 |
There's no difference there, that I'm aware of. The only thing I do extra to a type x, is the repinning.
04-01-2015, 08:12 PM | #28 |
Start over, the wiring, timing the beginning. If you missed the block and coil pack ground etc. It could be something simple. Triple double!
04-02-2015, 12:29 PM | #30 |
1. How can i find out if my harness is a type x harness. I know i have a type x motor (well at least that is what ive been told by a pretty reputable guy). 2. Any instructions on how to repin my 62 ECU to work for a "type x harness" Or is it me rewiring my "blue plug" to be compatible with a 62 ECU. Which way is it? 3. I plugged in my E5 ecu today and i got no spark again so i thought it just might be stuck in diagnostic mode because that mode screw on the ecu is broken. All at the same time i checked for voltage on my CAS and it all read -0.5v... so yeah i dont know what the means lol. So basically I have no working E5 ecu. I dont know if i have a type X harness or not. When i do plug in the 62 ECU i get spark, fuel and it cranks but no fire. Any tips? Any help? Please lol |
