Old 01-12-2015, 02:37 AM   #1
quickdiversion
quickdiversion is an unknown quantity at this point
Silvia and skyline sub frame questions
Hey everyone.
I am trying to collect information on subframes for the Silvia and the skyline.
Any and all information that anyone knows will be of help I am trying to collect some information.
So far the easiest and ones I am sure are right are:
- S13 and s14 rear subframes are interchangeable due to mount locations.
-I am sure I read somewhere the same with r32 and s13 rear subframes being interchangeable.
-The s13 and s14 front subframes are interchangeable in bolt pattern.
The information I am looking for is mounting location not substituting actual parts, I know it's possible, just tying to see what is mountable to what.
Also not sure about the mounting points between different skyline models (r32, r33, r34) rear subframes Being different or they will all mount to each other?
Anyone have information on the different skyline front subframes mount interchangeably with each other?
Any other this kind of information would be helpful.
Even if anyone has information about cross model interchangeably would be useful.
quickdiversion is offline   Reply With Quote
Old 01-12-2015, 04:10 PM   #2
quickdiversion
Anyone have any input?
Old 01-12-2015, 04:21 PM   #3
OutToWinPAHC
OutToWinPAHC's Avatar
OutToWinPAHC is an unknown quantity at this point
Send a message via AIM to OutToWinPAHC
I didn't read it all but I have done R32 and R33.
My R33 GTS25T is a hicas model. So I am using a S15 same bolt pattern as S14 subframe, with S-Chassis SPL toe arms and pushed the hicas ball joints from the rear knuckles and uses S-Chassis bushings (same a Z32, and non hicas R32,33,34)
For the R32 GTR I used a S14 subframe but had to use the S14 into S13 offset bushings. The S13 subframe is direct fit, but the diff mounting on the GTR is the same as S14 and I didnt want to switch to the low capacity diff cover.
R32 GTST you can use a S13 subframe, direct fit but you need to convert the rear knuckles to bushings aka pressout the hicas ball joint. Or run S13/S14 knuckes. Same for R33 using S14/15 sub
OutToWinPAHC is offline   Reply With Quote
Old 01-12-2015, 04:23 PM   #4
OutToWinPAHC
If your talking engine crossmember. you can bolt a S13/S14 engine crossmember into R32 GTS ,GTST just not GTR.
Same for R33 GTS/GTST and R34 GT and GTT.
aka if you want to LSX swap a non GTR you can buy a swap kit for a S chassis. S13 for 32, 14 for 33
Old 01-12-2015, 04:26 PM   #5
quickdiversion
Thanks for the info,
I don't know anything about skylines. What is the differences between the gts and gtr engine cross members?
Know anything about the rear subframes?
Old 01-12-2015, 05:06 PM   #6
OutToWinPAHC
GTR and non GTR are wider spaced in the front. R32 has a different set up all together with inner and outer lower ball joints in the front, and the tension rod mounting is much different. A non GTR engine crossmember wont fit a gtr and vice versa. Google pics to see what I mean.
If your looking to 26 swap a GTST you bolt the block arms on to the 26 block and mod the oil pan to get rid of the transfer case (google images)
Old 01-12-2015, 05:10 PM   #7
quickdiversion
When you say wider spaced,
Do you mean the bolt holes that mount to the rails or the width of the member itself.
I have been considering different swaps. As of right now I am manly looking for info that is difficult to find unless talking to someone with experience. Like what you are helping me ubderstand. I like to be well informed before making decisions.
Old 01-12-2015, 05:20 PM   #8
OutToWinPAHC
The frame rails are further spaced in the GTR so the GTS crossmember falls short, holes dont line up, no place to mount tension rod bracket. Different altogether
Old 01-12-2015, 05:22 PM   #9
quickdiversion
Now I got ya.
I have seen the front suspension setup differences between the gts and the gtr. Just didn't know how different the bolt patterns and mounting was.
Old 01-12-2015, 05:23 PM   #10
quickdiversion
It's that the same with all gtr models?
Old 01-12-2015, 05:38 PM   #11
quickdiversion
Would you happen to know the width off the gtr front frame rails, or have a clue where I can give that information, I have not been able to at the moment.
Old 01-25-2016, 08:44 PM   #12
Aetoc
Aetoc is an unknown quantity at this point
So to clarify...are you saying you can swap an s13 or a14 crossmember into an R34 GTT? They make a lot more swap mounts for the 240sx than the R34.
Aetoc is offline   Reply With Quote
Old 01-26-2016, 01:44 PM   #13
OutToWinPAHC
yes I have a lsx going into my r33 gtst aka same as gtt and i am using a S14 crossmember for this. Fyi its a 5.5 liter iron destroked 6.0 with twins, hello 1300whp
Old 01-26-2016, 09:50 PM   #14
Aetoc
Awesome, thanks. That helps me out a lot. Just need to get my hands on an s14 crossmember now.
Old 01-27-2016, 05:35 AM   #15
TheRealSy90
TheRealSy90's Avatar
FYI full race mounted a gtr front subframe, rb26, and AWD system into an S14 years ago. It CAN be done. But it's not a direct bolt on.
@OutToWinPAHC According to your info, an R32 GTR rear subframe should bolt up into an S13 using s14 offset swap bushings? Since you used those to put a 14 subframe in the 32 gtr.
Such a good signature.
Old 01-27-2016, 07:50 AM   #16
jlmason
jlmason's Avatar
jlmason is an unknown quantity at this point
So does that mean that the gtr diff bolts directly in to the s14?
jlmason is offline   Reply With Quote
Old 01-27-2016, 09:05 AM   #17
OutToWinPAHC
meh kinda. The front mounting holes have a bottom support, and then they use a different 6 bolt gtr specific axle. Plus its just a vlsd with a 4.08
Old 01-27-2016, 09:06 AM   #18
OutToWinPAHC
its all relative, they all interchange S14 to retain the GTR diff cover
Old 01-27-2016, 05:40 PM   #19
TheRealSy90
I just wanted to figure out the best way to get a gtr rear diff, axles and hubs into a 13.
