How To: Evo 8/9 Brembos on 240SX
I looked around for a while to find a clear write-up on installing the Evo 8/9 Brembos on a 240 and couldn't find one that I thought was very straight forward so I figured I'd make my own when I did mine
Here is a comparison of Evo 8/9 vs 300zx calipers. ![]() First off, I got a set of Brembos off a Evo 9. Came with the calipers, pads and rotors. Rotors are in eh shape so I'm either going to be buying new ones or having my buddy resurface them. Pads have some life on em so I'll keep em for now and the calipers are in decent shape until I want to powdercoat them. First step is to jack the car up and remove your lug nuts and wheel. Next step is to remove the 12mm nut on the back of the stock caliper that holds the brake line to the caliper. Watch out because there will be brake fluid in it and will run out of the line. I just threw a cup underneath to catch all of it. Next step after that is to remove the (2) 19mm bolts holding the caliper to the nuckle of the suspension. Once those are both off, the caliper will come off the rotor and the rotor will come off the hub. Here is a picture of where the bolts are on the back of the caliper. ![]() The next thing I did was cut the dust shield for clearance of the new rotor. I started by cutting the 90 degree bend off...after that I cut the corners off so that I had even more clearnace and didnt need to worry about anything rubbing at all. Heres a picture of once I cut it all off and hit it was some sandpaper. ![]() ![]() ![]() Heres also a picture of side to side comparison of size. ![]() I than dropped off the rotors to the machine shop for a quick resurface and started to strip the calipers. I took some sandpaper to them to get them scuffed up and took off all the rough spots in them. I than hit them with a nice coat of filler primer. I let that flash over night and than applied some paint the next day. Finishing them off with brand new Brembo stickers off eBay! (I know their missing the "B" in the middle of the circle for some reason...) Here's some pictures. ![]() ![]() I went with the Version 1 Evo 240sx Brembo brackets off of MadParts.net. They ran me $100 shipped. The installation was very easy from this point on. The bracket attached to the caliper with 2 bolts which I put some Lock-Tite on and torqued down. Than I slide the rotor on, put a lug nut on to hold it in place and set the caliper in place. 2 more bolts with some Lock-Tite slide through the OEM knuckle and thread into the adapter bracket. Then torque them down, bleed the calipers and your all set to go ! Here's a picture of the completed product! ![]() Last edited by CTblack240; 05-26-2012 at 05:17 PM.. |
![]() Join Date: Sep 2009
![]() Feedback Score: 15 reviews
I plan to do this as well. I have rotors,calipers,pad sitting in the garage. Going to resurface rotors. I planne on using the touge factory brackets. I'll read on and see how these are. Thanks for the write up.
straights are for fast cars, corners are for fast drivers. |
Well the fronts are both 4 piston but the Z32 brakes are only a 11" rotor where as the Brembos are 12.6"...For the rears, they are also both only 2 piston but I believe the rotor size is yet again bigger. In my opinon, they also look alot cooler than Z32s and are slightly bigger of a caliper too.
![]() Join Date: Jun 2010
ive been wanting to do this for a while now... i have alot of friends that are evo guys that will love this swap... are you only doing fronts, rears or all 4 corners???
I'm going to try doing the rears as well, I might just have to go with a hydro e-brake setup, I haven't looked into it just yet. Rotors finally got back from the machine ship today so looks like they are going on tomorrow! Pics coming!
![]() Join Date: Jan 2004
I wonder how it compares to this:
240SX Brake Upgrade - Import Tuner Magazine (Pricewise) How much did you snag your setup for? |
#13 | |
And OP, you could have made the brackets for half or even less. I just needed to buy a tap, which cost me $7 iirc, since I had all the other materials and tools on hand. |
#14 |
Nice writeup, I recently put a set of Evo X calipers on my S14 up front, after originally looking for VIII / IX calipers. The X rotor setup is significantly larger at 13.9 inches, and I'm running a carbon Centric setup with a 17/16 BMC.
Don't want to jack thread, but the writeup can be found here : Project 240SX – Installing EVO X Brakes | StockSpyder |
#16 | |
and FWIW, my rotors are 13.9 inches. thanks for playing |
#17 | ||
350mm = 13.78" or you can also check napa as all their specs are 100% correct. |
#18 | |
Really? wow.. i guess I should rip my X calipers off then huh? cuz its SO MUCH MORE weight than the IX setup.
again.. thanks for playing... ![]() |
#19 |
Johnphen, how does that bmc feel. I've got Evo 8/Sti set up waiting to be put on and I bought a 17/16 bmc but couldn't find any feed back as to pedal feel
http://zilvia.net/f/chat/331550-slyd...pic-heavy.html |
#20 |
If you look at the writeup, i was forced to use a banjo bolt with a short line to a 10mm inverted flare. With that line i found the pedal to be stiff, with about 1.5-2 inches of play before the caliper started to bite. Modulation isn't too great, but its a firm bite and there's more than enough feedback for me to get the job done ( no ABS )
I've since converted that banjo bolt nonsense to a fitting that simply screwed into the third brake fitting, the pedal is much more responsive and firmer now. I assumed the hokey shortcut line I used was putting some play in the line when the hydraulic fluid was being passed through it. I've had similar issues in DSM's when converting hardlines to braided, especially with the clutch master. |
#21 | ||
#22 | |
![]() Join Date: Aug 2005
Trader Rating: (26)
![]() ![]() Feedback Score: 26 reviews
CTblack240, great pick on brake set up
From right to left: stock s13 front caliper, J30, Z32, Evo ![]() J30, Z32, Evo ![]() Top is Z32 front pad, bottom is Evo front pad ![]() Left is Z32 rear pad, right is Evo rear pad ![]() Stock S13 caliper vs. Evo caliper ![]() ![]()
"All I have in this world is my balls and my word, and I don't break 'em for no one..." Last edited by jrivera; 05-25-2012 at 07:55 AM.. Reason: Added more pics |
#23 | |
Trader Rating: (26)
"All I have in this world is my balls and my word, and I don't break 'em for no one..." |
#24 | |
Conversely, STI's fit with a simple 3mm spacer between upright mounting tabs and cali mounting tabs. Your absolute best bet is to just find STI calis and use Evo rotors or simply run Z32s if you want little to no work. |
#25 | |
Trader Rating: (26)
Also, I posted pics of the wilwood caliper as a possible e-brake solution since that's what I bought back in the day.
#26 |
![]() Join Date: Jan 2003
Trader Rating: (43)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 43 reviews
I like the sti as complete swap. Second choice is sti/evo fronts n z32 rear. yeah u can put the evo rear but needed mod on the caliper ears to make new mounting holes! This takes alot of time plus it weakens the calipers since your cutting a big chunk! make it simplr guys, sti/evo fronts and sti rears or z32!
fdrea |
#27 |
Trader Rating: (26)
I definitely agree that it will be more work. Back then, no-one offered brackets for the front either so the whole swap was inherently a lot of work.
What I meant was having the rear caliper positioned like the rear caliper on the Dodge Charger. ![]() Anyhow, I'm done. I'm interested to see CTblack240's ideas for rear calipers.
#28 | ||
As for the charger setup, that will not work due to the rear link in the way. The only way to fit this by repositioning the calis is by either welding on new mounting ears or drilling into the body of the upright with your own sort of mounting ears, on the lower side of the upright towards the rear of the car. You have the right idea though. Someone I know is either in the process of doing this, or already has done this. But still is a lot of work to get a cali and rotor to work. At that point, I would just find a radial-mount aftermarket caliper and a floating rotor setup to get to work in the stock position with very minimal bracket fabbing, which again, would be something I would do if I had the time. |
#29 |
Trader Rating: (26)
CTblack240, great job on cutting the dust shield. Most people do a really crappy job on it.
#30 |
I'm most likely going to go with STI rears with Evo rotors...Seems like the most efficient idea so I don't look like an idiot with huge brakes in the front and stupid little rears. And thanks, I like to do my mods correctly and not just hack it all up haha
brembo, s14 |
