![]() Join Date: Aug 2015
Misfire Sr20det
Searching and reading for a while !
Figured I'd make a thread So my s13 sr has a random misfire at idle Has a really bad cut out putting anything after 20% throttle I don't know if my worn cam lobes have anything to do with it <a href='http://i.imgur.com/HRp65Rh' title=''><img src='http://i.imgur.com/HRp65Rh.jpg' alt='' title='Hosted by imgur.com' /></a> Timing marks are correct but when using a timing gun it was way off to get it at 15* the cas is at the end of the adjustment window ... Things I've tested Tried a freinds igniter Unplugged each coil pack and injector Tested cts and cleaned connection Cleaned maf Checked all clamps for possible boost leak (haven't done a test) Mods Walbro 400 (I know it's excessive) Stock fuel lines Z32 fuel filter (1hour of run time on it) Stock 370inj Wiseco 9.0 comp Pistons 87mm Apexi 1.5 - 87 Stock valve tran fresh seals T28 s15 bb Fmic It was doing the idle bog/misfire before I had a piston meltdown but only popped every now n then under load . I'm gonna do a boost leak soon but in the mean time can I get some ideas tossed up.. Let me know if you need any more info. Thanks Also I don't know afr #s yet . Wideband on the way |
Here are a few ideas. Clogged fuel injectors. Test fuel pressure. TPS has to be unplugged when checking timing, also I could not get an accurate reading off the timing loop. I had to use a plug wire (ka24) between the number one coil and number one spark plug to get an accurate timing reading.
Sent from my SAMSUNG-SM-G920A using Tapatalk |
![]() Join Date: Nov 2007
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
I'm not too sure. I had an issue with an misfire at idle, replaced a bunch of things and it ended up being the cas. My misfire would get worse the longer I drove it. It would bog a little under boost though.
My Rb had a nasty misfiring issue, especially in the higher rpm range.
I tossed in some fresh Ngk V-power BRK7E(s?) plugs and gapped them to 0.22. Running perfectly now, way better than the old NGK iridiums that were in it. Only costed me about 25$ for 6 plugs. Not sure what ones to use in an Sr as mine blew up long before I got to change the plugs in it. |
