06-05-2016, 06:08 PM | #1 |
SR20det coolant lines loop or plug?
So there's 3 outlets under the intake manifold of a s13 sr20det, thermostat housing outlet, coolant temp sensor housing outlet and the water pump outlet. I am running a journal bearing turbo and eliminated the heater core. Is everyone plugging the outlets? Would this cause issues in flow? If your looping them how are you looping the three outlets?
"Being a SSR wheel nude model is NOT easy, I just make it look like it is!" |
06-06-2016, 11:28 AM | #3 |
06-06-2016, 12:13 PM | #4 |
I can loop two of the lines but it still have one outlet remaining...
06-06-2016, 12:15 PM | #5 |
This involves cutting and welding old corroded pipes. This also positions the line completely loose.
QUOTE=ryandriftingfat;6073741]http://givemeshred.com/sr20det-coola...implification/[/QUOTE]
06-06-2016, 12:20 PM | #6 |
Does someone make a billet or custom temp sensor housing that bolts on to the side of the head with two outlets? I have seen the ones that mazworx makes for the vvl conversion kit but these are not compatible. Something similar to this would allow you to easily loop the entire system and keep both temp sensors...
06-06-2016, 12:27 PM | #7 | ||
06-20-2016, 04:10 PM | #9 | |
