11-02-2015, 06:16 PM | #1 |
Need help with my 240sx! Wont start
Hey! im very new to this website but wanted to give it a try and see if i can get any help.
i own a 95 240sx with a stock ka engine. went to start it up this morning getting ready to head out to work and everything function properly. the end of the day arrived and i went to go start my car, but unfortunetly it didnt want to start. i use the remote to unlock my car, put the key in the ignition, turn it over and everything looked like it was working fine. then i try to start it and it completly died on me. the lights in the instrument cluster doesnt work, the remote to unlock and lock doesnt work, the radio doesnt work... but my headlights work, my interior dome light works. even the lock and unlock button works. put a jumper to it and nothing changed. tested battery, its was fine. starter is working, 12v fuse is alright and so is ignition swtich fuse. so im lost in what i should do or start fixing so if you guys have any ideas that be great!! thanks! |
11-02-2015, 07:02 PM | #4 |
With loose terminals some things might work, then youll go to turn the engine over and everything will just turn off. Had this happen to me recently and ultimately bought a new battery *edit* and terminals *
11-03-2015, 10:18 AM | #6 |
You are in Chicago...if the car spent a few years of its life in road salt conditions, then your battery may be fine but your battery terminal connections, or the negative ground wire/positive cable to the starter may be corroded.
That would allow for some power (headlights, radio, dome light) to function just fine but not enough for the starter to be engaged. A corroded cable may lose 90% of its energy transfer capability. As our cars age- this happens. Solution is to replace cables and protect them in the future. Use a good quality dialectical grease. |
11-03-2015, 01:31 PM | #7 |
True, but i put a jumper box to the battery and it made no change to it. i was checking my harness that goes around the driver side harness, and tested the each wire to see if current is going through and i found a black and yellow stripe wire that doesnt have any current going through it. what you guys think?
11-03-2015, 01:48 PM | #8 |
11-03-2015, 06:49 PM | #9 |
I know when my s13 was acting the same say I checked my connections from the fuse box in the engine bay to my battery terminals.
They were extremely corroded and while externally they looked fine they weren't. I had to pull the battery out of the tray check all the grounds and checked the main power source that comes from the fuse box to the battery. I fixed a ground issue I found and have been good to go since. Hope you figure it out! Wiring issues are the worst! |
11-04-2015, 05:56 PM | #13 |
I guess I should have been a little more clear my fault. Most of the corrosion was under the fuse box area. Everything looked fine until I removed my battery and got down and looked.
11-04-2015, 06:19 PM | #14 |
Might be your cables
I recently had a similar problem. While it wasn't my battery terminals, that were corroded, my battery cables had corrosion inside them. I ended up needing to have new cables fabricated. Not real expensive, and solved all my electrical woes.
I am a leaf on the wind...watch me soar. |
11-05-2015, 03:54 PM | #15 |
still no luck, havent been able to had to time to look at her yet, this weekend should be good. i was able to drive her home, i passed a wire straight to the battery to the igntion wire. a white wire. she started up right away with no problem what so ever.. assumed it was my igniton relay, bought a new one and plugged it in and still no results. -__-
11-05-2015, 04:07 PM | #16 |
Basically, car still wont start. no clicking with starter, nothing. no lights turns on with my cluster. apperantly im getting no power towards my igniton wire, so had to hook up a wire from the battery straight to my ignition wire to start it and it started up right away with no problem.! so then i switch the igniton relay with a new one thinking that could of been my problem and still no luck..
