s14 sr swap ac wiring
ok ive been to the end of the internet and back and cant find it ive tried using the search tool and ive looked at alot of threads all i need to know is what has to be done on a sr swapped s14 when wiring up the ac compressor a diagarm and a step by step would be great
ps my blower motor and everything works but when i press the ac button the compressor dosent kick on also i bought the car alrerady swapped so i have no idea what was done before any info would be great one more thing can you please post some pics of the under the hood fuse box mine seems to be missing a whole block of fuses my car is a 95 base with a s14 sr swap |
![]() Join Date: Jan 2009
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
The compressor comes off the chassis wiring that splits off from the part of the harness going over the drivers side wheel. Doing a swap should have no effect on the AC wiring.
#3 | |
![]() Join Date: Jul 2005
There is a trigger wire in the F3 plug that needs to be tied or moved to another pin IIRC. Its been years but I think it might be black/pink and yellow/black. I have a thread on FA about this, in a 95' doing an S13 sr20det swap, I have a pinout diagram up
edit: found this, which is something jerry wrote, along with another guy, anyways it might help Quote:
Thanx man ill check it out I have to be honest you restored my faith in the 240 community I'm new to the community ,coming from honda, and almost everyone I've encountered have been such a tool and act like they can't help anyone out
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
i think i may have figured out the problem, there is no pressure in the system, im not 100% but if there is no pressure then the compressor wont engage, is this correct?
I have a 97 or I would. Unless you want a pic of my 97 anyways. The FSM should show you everything in your 95. You can get 95 240sx FSM easily.
Right, if you have no A/C gas, there will be no power going to the compressor. If you want, PM me your email and I will send a wiring diagram I have that might help. |
#8 | |
Sorry for bringing up an old thread but I am in the process of doing this on my 97 and don’t have the pin 16 wire on either side too. Reading this is pin 43 On my 97 like the pin 16 on 96?so I just hook up 46 and 43? And I have to ground the triple pressure switch as well?
