05-09-2015, 08:43 PM | #1 |
ka24de pre turbo mods
So the plan is to turbo my ka24de which is stock right now. just got the car from paint and am ready to start buying parts. plan is to start with building bottom end then turbo.
Ive basically got what I need in a list for the turbo, but my question is.. Is there mods that I can do before pulling the motor and tearing everything down for the turbo that will benefit me in the long run? my first purchase will more than likely be oil pressure gauge and mount all that up. and might as well get gauges needed for the turbo and install, just not hook up ya know? not looking for a lot of down time, things I can put on in a day and still be driveable. thanks |
05-09-2015, 08:45 PM | #2 |
Wideband
Oil Pressure Boost gauge Oil pan with return bung welded in Exhaust Diff Fuel pump
MRP Manufacturing |
05-09-2015, 08:46 PM | #3 |
already have lsd in car. Was thinking of putting wideband on steering column. boost and oil on a pillar. thinking custom exhaust (not sure if cheaper than just buying something) and can I put the bung in and seal it off until turbod?
05-09-2015, 10:02 PM | #4 |
Yeah you can cap off the bung until your ready to turbo it.
Upgraded radiator. Koyo or mishimoto will do the job. I run a stock clutch fan with a mishimoto radiator and it does just fine. You could do electric fans if you want just get a good quality fan controller.
05-11-2015, 05:59 PM | #5 | |
The stock 240sx exhaust for the ka24de will support 250~ rwhp and is identical to the one found on the S14/S15 Silvia with sr20det. |
