Old 04-10-2013, 09:28 PM   #1
Ninjataco
Ninjataco is an unknown quantity at this point
Fuel flood?
well my 95 240 revs super high after i start the car, idk if its because its flooded with fuel because i changed my tps and i did open the throttle alot to maneuver it in but im not sure if its that ?
what can i do to fix it and/or tell?
Ninjataco is offline   Reply With Quote
Old 04-10-2013, 09:33 PM   #2
OrangeVirus1
OrangeVirus1 is an unknown quantity at this point
vacuum leak. leaks when it's cold, and the heat then expands the metal and closes the vacuum leak.
OrangeVirus1 is offline   Reply With Quote
Old 04-10-2013, 09:54 PM   #3
Ninjataco
before i changed the tps and opened the tb a lot it ran decent
Old 04-10-2013, 09:56 PM   #4
2.5T_/<ouki
2.5T_/<ouki's Avatar
2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice
Did you make sure to set your TPS correctly when installing it? You could have F'd your TPS up. I had this same problem on my car and it was the TPS. Is it the stock TPS that you swapped it with?
http://www.youtube.com/watch?v=rKK7QdochkI
2.5T_/<ouki is offline   Reply With Quote
Old 04-10-2013, 10:00 PM   #5
Ninjataco
it had an auto one and i replaced it with an oem i had, how would i set it correctly?
Old 04-10-2013, 10:17 PM   #6
2.5T_/<ouki
Did you not see the video that i provided? It shows you how to set it correctly.
Old 04-10-2013, 10:41 PM   #7
trxrx7
trxrx7 is an unknown quantity at this point
yeah set tps correctly, spray brake cleaner on all the vacuum hoses and see if idle changes that way you know if you have a leak, also disconnect idle air control valve if nothing changes than its not working(had that once on my car it idled high to) could be a lot of things gotta go step by step
fd3s fc3s mr2 s13 s13 s13 s14 s13vert aristo2jzgte bmw-e46
trxrx7 is offline   Reply With Quote
Old 04-12-2013, 07:32 PM   #8
Ninjataco
well i tried but it wont set to .444 when it lines up with the bolt holes it reads 1.5-1.8
idk if it the tb its self or what?
Old 04-12-2013, 08:51 PM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Seriously? Where'd you pull that info from? How about the ECU dumps extra fuel on cold start to help get the car up to temp?
CLICK HERE!!!
