Advertiser Announcements and Feedback This is where vendors can make announcements about upcoming promotions, events, items, etc. Vendors may also create threads here for the purpose of market research or other customer feedback. |
01-18-2012, 01:23 PM | #1 |
S-Max NEW Power Steering Reservoir
S-Max’s extruded aluminum Power Steering Reservoir is completely hand crafted. This reservoir features a machined cap that is available with or without venting, -8 ORB return, -10 ORB feed and an in house designed site glass to easily check your fluid level. S-Max also incorporated a proprietary return baffle to reduce aeration and help keep a positive flow. The reservoir measures 6.5“ tall by 3” in diameter with an operation fluid volume of 12 oz. The reservoir features S-Max's exclusive 360 Degree mounting solution for ease of installation. Click to buy Power Steering Reservoir |
01-18-2012, 01:52 PM | #6 |
01-18-2012, 02:08 PM | #9 |
S13, SR20DET with top mount turbo set up. AN fittings work with this you say? ARESUM!
I think what you have here will work for me, here's what I'm working with for reference. Planning on mounting the power steering pump down where the a/c compressor should be, so there will be plenty of room to mount it on the frame rail. |
01-18-2012, 02:27 PM | #10 | |
01-19-2012, 08:28 AM | #16 |
very nice. a little pricey but from the looks of the crafsman ship i'm sure it's well worth it.. i'm am definitely impressed.. like the site glass. most would have went with the crapy side mounted plastic tube and the thing would have ended up leaking after a month of use... almost tempted to get one cause it looks better than my OE crap.
))-> sil front on.. time for rocket bunny kit<-(( |
01-20-2012, 01:07 PM | #19 |
nice peice...would you have to convert to braided steel lines after install of this? or can it be used with oe lines...probably a dumb question, im just askin it to get it out of the way..lol.
good luck with the sale. |
01-20-2012, 02:37 PM | #20 |
The reservoir has threaded bungs; you can see in the pictures that you can use AN or barbed fittings.
S12 || KN13 || S13 || B16 |
02-01-2012, 09:35 AM | #23 |
