02-24-2011, 08:59 AM | #1 |
lost timing on ka24e
Long story short, i removed the oil pump and dizzy without marking it and to make it worse the engine wasnt on TDC.
Now i need to know how to set timing. My understanding is that all i have to do is, 1. set the the engine on tdc, 2. Aligne oil pump with marks 3. install dizzy where the rotor points at cylinder 1. Am i missing anything? |
02-27-2011, 06:38 PM | #2 |
UPDATE!!
I got the car running. All i did was put the motor on TDC and installed the oil pump and dizzy. My problem is that now it makes a really bad noise. I did nothing but replaced the oil pump gasket. I have an oil press gauge and it says that the pump is in working order. anyway here is a video. YouTube - 046.MOV |
02-27-2011, 09:25 PM | #4 |
To me, it sounds like it coming from the cylinder head. Almost as if the valves are hitting or lifters unblead themselves. I didnt touch the chain at all so i doubt thats the culprit. I did however checked to make sure that head and bottom block where aligned properly and they are sooo im out of ideas. ill keep at it tomorrow.
02-28-2011, 08:30 PM | #6 |
UPDATE!!!!!!
car runs perfect!! put engine on tdc (compression stroke) aligned oil pump and spindle and intalled dizzy starting just before spark plug #1. Once i removed i noticed the oil pump was not aligned. Do not quote me on this but i believe when the oil pump is aligned it provides better lubrication. Anyway im quite happy my car is running now. |
