07-19-2010, 08:42 AM | #1 |
Solidworks users........
Does anyone know a good tutorial book that goes over making threads? I'm having trouble with this and the solidworks bible I bought is no help at all. I'm using 2007 if that matters, thanks :/
07-19-2010, 08:48 AM | #2 | |
if i get a response from my professor i'll PM you |
07-20-2010, 01:50 AM | #6 |
Trader Rating: (41)
Feedback Score: 41 reviews
Damn, I have a really great intro to Solid Works book that I used when I was doing engineering. I just looked through it. Nothing on threads though.
ISBN: 978-0-07-337532-8 if you are interested. I can sell it to you for pretty cheap. Don't need it anymore. |
07-20-2010, 06:47 PM | #8 | |
Ill give that a shot, its not so much getting the pitch but more the thread profile or using the extrude/cut and making the right cutting tool. |
07-20-2010, 07:15 PM | #10 |
I got the spiral/helix part, I just couldn't get it to sweep. Also I didnt know what size or profile to make the triangle for 7/8-20 threads. I guess its more of not knowing the specifics of making threads because all the other programs I have used automatically made them for me.
07-21-2010, 02:28 AM | #11 |
There was this awesome tutorial I found online once, but I have yet to find it again. It helped me make some pretty freaking awesome threads if I do say so myself. I'll see if I can find it again.
Found it! http://www.solidworker.com/167/threa...metic-threads/ Best video I think |
07-21-2010, 07:15 AM | #12 |
Why do you need to make actual threads in the first place (rapid prototype)?
If you are making a drawing to have a part fabricated the only thing the machinist needs to know is what the thread is (7/8-20 in your case) and how long. In solidworks to specify an external thread you simply have to insert a cosmetic thread, specify the thread, and external minor diameter. A cosmetic thread will show up on your drawing with the a diameter of the external minor dia. All the thread profile info should be found here: Screws Extra Fine Thread UNEF Series Ps: one of the tricks to getting it to sweep is to make sure the sweep profile (triangle) is located on the end of the path (helix).
'96 Nissan 240SX KA-T ─ '05 Grand Cherokee Laredo 4x2─'85 Nighthawk |
07-21-2010, 10:06 AM | #14 | |
Im pretty sure I go the triangle on the helix, ill give it another shot when I get home. Thanks everybody for all the information.! Im pretty sure I downloaded that a while ago, I just have to find it. |
07-21-2010, 10:27 AM | #15 | |
08-01-2010, 10:59 AM | #16 |
Ok one more stupid question, when you use the smart dimension tool does that dimension the drawing so when you send it to someone to machine its good or do you have to go in after and dimension the whole thing again?
08-01-2010, 11:03 AM | #17 |
Smart dimension dimensions the stuff you want it to dimention. You want. To dimention. Thelength of a bolt? Click on the top and bottow edge and drag to the side. You still need to practice good dimensioning habits so a machinist can clearly read your drawing.
08-01-2010, 02:21 PM | #19 |
i'm looking to get into autocad and solid works. whats a good easy and basic way/place to learn it. i work full time and sometimes more so its a bit difficult to go to classes an such.
any info would help. |
08-01-2010, 02:36 PM | #20 | |
But in all honesty, I didn't really learn anything new at school than I did at home. However, AutoCAD has change dramatically since I started using it, which was 2000i and R14. For 2D plans, AutoCAD, imo is far superior and one of the best CAD systems I've used. Solidworks is great for 3D but I've always been biased towards Autodesk Inventor because that's where I started with. Plus I think inventor doesn't have as many bugs and is more user friendly than solidworks. Again, probably because I started with it and never really gave solidworks a chance. What I did when I started was to just look through the help (F1) and try out all kinds of random commands, because back then I was on 56k, but you can get a lot of helpful tips and suggestions online now, so go on CAD forums and youtube videos to start. I don't think smart dimension constraints the dimension though, but don't quote me on that. |
08-01-2010, 03:45 PM | #22 |
i am soo lost on this stuff sometimes, solidworks is awesome, but I am having trouble designing some things, I guess practice makes perfect, so I m going to keep it up to figure it out. Fuggy
08-01-2010, 06:29 PM | #23 | |
Thats how I picked up Illustrator and Photoshop. |
08-02-2010, 09:28 PM | #24 |
If you are designing a part that you are going to send to a machine shop, you do not need to render the actual threads. Fully rendering all the threads in a large assembly would destroy Solidworks. Just use cosmetic threads and make sure that the drawing you send to the machine shop calls out the thread size.
08-03-2010, 10:08 AM | #25 | |
Spot on. Unless this is some assignment where you are showing the professor that you know how to make threads, modeling them is not worth it. Machinists, and CAM packages dont care what the treads look like on the CAD screen. You just call them out on the drawing....size, pitch, and depth is all you need.
www.formula1.com |
08-03-2010, 10:38 AM | #26 | |
AutoCAD is a great way to learn the basics. But if i was you, id get Autodesk Inventor. Its easier to do 3D stuff on Inventor than AutoCAD. Inventor and Solid Works are pretty similar. Pro-E is the hobo version of both of those combined. Inventor is really user friendly and on the cheap side of all the programs. I use it, AutoCAD, and Unigraphix NX9 everyday at work. And if you can use AutoCAD and have a general understanding of it, then the others will be easier to learn. |
08-03-2010, 10:41 AM | #27 | |
95% of the CAM packages wont recognize actual threads. The softwares are designed to tell them what threads are used and if you make real ones they see it as a design feature, and wont be able to tool it correctly, or it will throw up an error saying its impossible to do it. |
09-23-2011, 01:33 PM | #28 |
Ok, new question. I have gotten a lot of the basic stuff like 3D parts and sheet metal stuff down. I am trying to open a .dxf file I exported from illustrator of a logo I want machined in a part. Every time I bring the dxf in it plants it on the drawing im working on and I cant move it. I can extrude it but its locked where its at.
09-25-2011, 02:21 AM | #29 |
Solidworks help section is great. You design the parts and learn function as you go. I used to be good at it, but that was the 07 version.
I like solidworks better than Autodesk AutoCAD. Which is like the same company, but that was then. |
09-25-2011, 11:50 AM | #30 |
Autodesk and Solidworks arn't from the same company and are veeery different.
AutoCAD is such more powerful tool when working with 2D compared to Solidworks but for 3D Solidworks is the easiest of almost all the 3D CAD software's but it's really unstable when working with complex designs. That's my only down fall with using solidworks. |
