Old 11-22-2016, 06:11 PM   #1
tb13
tb13's Avatar
tb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to behold
BUILT SR20DET - Complete Long Block
Picked this motor up for my swap, but I need some extra cash so it needs to go. This motor came out of a running car and has prefect leakdown/compression.
S-S-S-S-SOLD!!!
Motor build consist of:
Wiseco 86.5mm 9:1 pistons
Manley Rods
ACL rod bearings
ACL main bearings
ARP headstuds
Cometic Headgasket
BC 264 cams
BC valve springs
BC titanium retainers
BC SS valves
New OEM water pump
New OEM oil pump
Also included/on the motor:
New OEM valve cover gasket
New OEM intake manifold gasket
New OEM exhaust manifold gasket
New OEM rear main seal
New OEM front cover seal
New IACV gasket
New throttle body gasket
Stock intake manifold
Throttle body
Alternator
PS pump (No pulley)
CAS
IACV
Coilpacks/harness
Knock sensor
Motor mount brackets
Extras that I can include for an added cost:
Radium top feed fuel rail/ID1000's
ARP flywheel bolts
R35 MAF sensor
Nistune Redtop 62 ECU
S14 valve cover (to make a S13.4 cover)
Tomei FPR
ISIS Radiator hoses
tb13 is offline   Reply With Quote
Old 11-23-2016, 07:48 AM   #2
jedi03
I have similar build...killer deal on this!
Old 11-23-2016, 05:25 PM   #3
tb13
tb13's Avatar
Thanks!
Bump! Open to reasonable offers!
Old 11-24-2016, 01:33 PM   #4
tb13
tb13's Avatar
Happy Holiday bump!
Old 11-24-2016, 04:29 PM   #5
cjsjodin
cjsjodin is an unknown quantity at this point
If you part up lemme know I need springs and retainers
cjsjodin is offline   Reply With Quote
Old 11-24-2016, 06:20 PM   #6
tb13
tb13's Avatar
Not going to take apart a perfectly good motor.
Old 11-25-2016, 04:31 PM   #7
tb13
tb13's Avatar
Bump! Screw black friday, this is the best deal out there!
