Old 12-08-2013, 01:18 PM   #1
951drift
951drift is an unknown quantity at this point
KA help auto transmision stuck in park!!!!!
so i was driving back home from work and my auto transmission gets stuck in gear and keeps rolling when i put in park, kept switching through the transmission through the gears then it gets stuck in park so i turned the car off, now it is stuck in park and will not engage into any gear but i can shift through the gears but makes a grinding noise like something broke what is it i usually drive stick but im broke and working temp jobs so need the car available asap thank you
951drift is offline   Reply With Quote
Old 12-08-2013, 07:24 PM   #2
Frank_Jaeger
Check the linkage from the shifter to the transmission. It's a metal rod, it might've come off or you bent it.
Frank_Jaeger is offline   Reply With Quote
Old 12-09-2013, 02:13 AM   #3
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
^^ this, and if that looks fine it may be where it actually connects to your valve body
4x4le is offline   Reply With Quote
