07-03-2022, 04:59 PM | #1 |
Built SR20DET Full Swap
This is a complete, drop in and rip swap. ECU has a low boost map used for break in at 10psi making 299/243. Setup is easily capable of 400whp+ with the boost turned up. Entire setup maybe has 500 street miles on it plus the dyno time.
S13 SR20DET block WPC treated crankshaft WPC treated Nissan OEM main and rod bearings Nissan OEM oil pump w/ WPC treated gears S14/15 oil pickup CP 86.5mm 9.0CR pistons Manely Rods Sianar Motorsports -10AN breather Nissan OEM main bolts Nissan OEM timing components ATI super damper 180SX head ported & polished by Port Flow Ferrea dual valve springs Ferrea +1mm valves Dual guides Tomei 260 procams Apexi head gasket Mazworx ARP Headstuds S13.5 valve cover w/ -10AN fittings Link G4X S15 PnP WS Pro harness (S13) Taarks R35 coil pack kit 2x AEM X-Series Can Gauge AEM X-Series Wideband 2x AEM 150psi pressure sensors AEM Map sensor AEM IAT AEM flex fuel 3 port boost controller ID1050X Radium fuel rail Radium Direct mount FPR AEM 320 fuel pump -6an fuel lines Genuine Greddy intake manifold Tomei turbo manifold HKS GT2530 rebuilt w/ billet wheel Tial IWG actuator All OEM MLS gaskets Mazworx manifold hardware PBM cobra downpipe 3in custom turbo inlet w/ PCV provision 3in AEM air filter Nuke Performance catch can HKS oil cap KTS Lowdown oil pan Koyo N-Flow HKS radiator cap Nismo thermostat S15 water neck New OEM fan shroud Clutch fan Samco radiator hoses PBM HMIC Nismo engine mounts Nismo transmission mount SR20DE transmission ATS Magnum single disk clutch 180SX driveshaft Asking $12,500 for everything. Located in Phoenix AZ, engine is still in the car, can come go for a ride before I pull everything or provide in-depth video.
07-03-2022, 05:41 PM | #3 | |
I'm also considering selling my car as it sits, if anyone is really interested check out my build thread. Click Click
