03-05-2014, 07:46 AM | #1 |
Reverse Lights not working
Okay I've searched and searched this and other forums but none seem to answer my question. I did an SR20DET swap on my 1993 s13 240sx with a s13 SR20DET. My S13 was manual from the factory so that's not an issue. My reverse lights were working when I have the KA24DE engine and trans in it. but when I swapped in the SR the reverse lights no longer work. I'm using the lower harness from the KA trans and the sensors from the KA tran since they plugged right into the harness. My thought is that maybe the SR trans doesn't work with the KA reverse light sensor/switch. Can anyone help or confirm this, or if you've had this problem and fixed it.
03-05-2014, 09:25 AM | #5 |
well i know i have the right switch in the right location because I followed the picture layout the the switches on both trans, and took the right switches out. I'll check my fuse though.
