![]() Join Date: Jun 2005
What Crazy Electrical gremlins do you have??
Ill start off. When I turn on my map lights my seatbelt lights turn on. Also before i redid my steering wheel my horn would only honk when turned 180deg. Also when my auto seatbelt opens my clock turns of and only turns on when its closed.
What strange elec problems do you guys have? |
Admin Asshole
![]() Join Date: Mar 2002
Whenever I adjust my drivers seat (slide it forward or back) my seatbelt chime will randomly go off for the following week. That's my S13 Electrical Gremlin. Also when I bought the car my tailights were dimmer on one side, but I solved that by cleaning the grounds inside the housings.
steering wheel horn only honks at 180 degrees
for the guy that has this problem, you should take the steering wheel off lightly sand and then re-grease the contact points. this happened to me when i put on a momo hub, i had to dremel off the plastic surrounding the hub to get a nice contact. |
![]() Join Date: Apr 2005
if i open my door twice after the car cutting off the hazard lights flicker untill i put the key in and turn it. also if i use my windshield wipers for a good amount of time a day they will not cut off unless i take the fuse out.
-1990 240sx hatch sr20det- gt35r, blah blah blah |
My girlfriend's S13 dash lights flicker between the day setting and the night setting when she has the headlights on. She also has the most schizophrenic temperature gauge known to man. I mean it jumps all over the place. Goes down while cruising goes up to max at idle. I checked the engine, it was not overheated.
My 280z doesn't have too many gremlins, but here's kinda one: I had to rewire the turnsignals, so whenever the headlights are on, it takes like 2 seconds for the signal to light up after I flip the switch.
Long live the Datsun Z. |
#7 | |
Same here....... |
![]() Join Date: Nov 2003
i have my headlights up all the time (all the way up not sleepy eyes) and sometimes the passengers sicde will go out every now and then. till i either hit the hi beams or turn it off and on again. DAMN THESE ELECTRICAL GREMLINS!!!!!
#12 | |
Thanks flying chicken yeah i knocked it out when i changed to a personal wheel. |
I can only get the sunroof to go into the tilt position if its the third thursday of the month on a leap year and there is a full moon.
My horn stays stuck in a wierd way. The sound it makes is like a plusing type beep not one long beep. I pulled the fuse out months ago. lol. I have the stock radio, when I turn it on it'll stay on for a few seconds, then turn off. I have to do this back and forth for a while untill it stays on. The CD player no longer works. (Alpine HU coming when I'm no longer broke)
#15 |
![]() Join Date: Nov 2005
all of my interior lights (except boost controller and gauges) and exterior lights pulse when the car is idling...alternator is good and so is battery
once driving everything seems to be fine or it just pulses so fast I can't tell it's happening
#16 | |
when i press my brake, all dash lights dim.
all my brake lights work..but when i press it..one of em turns off.
#17 |
Admin Asshole
Sounds like a lot of people need to go through their vehicles and clean all the grounding points they can find. Myself included.
#19 | |
![]() Join Date: Jun 2004
when i roll my drivers side window down all the way, the little automatic power window amp box thingy will click, and idle drops about 200rpm, then click again and idle goes back up-i guess that thing drains alot of power lol
id fix it or get a new one, but im lazy and s14s are scarce at the local pull-a-part and those boxes are even harder to find!
![]() Quote:
#20 | |
#21 |
No Limit Soldier.
![]() Join Date: Jan 2006
This is a bit wierd, bit on my s14 whenever I push on the brakes the stereo resets hahaha. I've been cleaning out the wires in my dash, I've located all of the stereo component wires, along with the negative postiive and nneutral.
Hopefully i can get this shit solved asap. Because I would like to listen to the music for at least 1 minute or so before the bitch resets on me.
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only" |
#23 | ||
![]() Quote:
#24 | |
#26 |
turn signals don't work, but hazards do.
radio won't work right. will turn and and off and on and off.
http://bhworld.wordpress.com/ |
#27 | |
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
#30 |
my headlights wont go down, and my seatbelt light always stays on and when I drive it flickers on and off, my cluster clock doesnt work, my third brake light doesnt work.
