![]() Join Date: Sep 2011
![]() got a 97 se kouki about 3 months ago and already spun a rod bearing
that sucks man im kinda pissed the guy i bought the car from added me on facebook so i could see some vids of the car and once this happened and i posted about it on FB he deleted me lil bastard he was a mechanic for Toyota im sure he knew it was coming thats why he sold it, but its all good Carma is a bitch! lol
here is some pics of the issue #3 spun Pictures by kouki_drifter - Photobucket
Ok OEM crank,eagle H beam rods, acl rod and main bearings, super tec valve seals, and arp main studs on order wiseco piston heads, port, polish, 3 angle valve job, port match and decking coming soon yesss!!!
![]() Join Date: Dec 2006
Well parts from fr sport were $1200 and some change not including the piston heads, head work is $505 @ sileighty thanks man I wasn't sure what to look for thanks for the help so i could get this motor rollin
![]() Join Date: Feb 2010
Thanks was looking for more of a complete rebuild $. Should have been more clear. I'm just getting prepared for a future rebuild even tho (knock on wood)all is good.
O ok I see well I don't knw a full amount yet I'm still in the process but it all depends on the brands you go with and what all you wanna do, I'll list pics and parts and the full amount once Im done with mine so you can get an idea of how much
ok guys i got an important question? ok i ordered a new oem crank and standard eagle H beam rods so do i go withe the #'s and colors that are on the crank for the rod and main bearings? or do i just order standard? cuz thats what i did i just ordered standard bearings, am i ok? i would really appreciate your help thanks!!!
#14 |
this is the crank and bearings
Nissan OEM Crankshaft S13 S14 S15 SR20DE(T) Brand New ACL 5M2964H/X Race Main Bearing Set Nissan SR20DE/SR20DET ACL 4B2960H/X Race Rod Bearing Set Nissan SR20DET Eagle CRS5365N3D SR20 SR20DET Chromoly Forged Rods am i ok with this??? i got standard every thing |
#15 |
nobody at all??? ok my oem crank numbers are:
first line: 00000 2nd line: 0000 3rd line: 0930B so how do i figure out how to find the bearing size i need? i searched but didnt come up with how to do it |
#16 |
ok so i found that because i am running a new oem crank that acl rod and main bearings would be ok because the crank is new and as long as the oil clearance is within .00008 to .00012 it will be ok, is this correct? i did a crude measurement of my crank with a digital caliper and it measured 47.90mm and i also measured my rod with bearing installed and it measured 47.98mm so the difference is .08mm is this an ok crude # i know plasti gauging is the proper way to do it but i just wanna make sure im in the safe zone now that way if im not i can get new bearings if i have to right away so im not putting a damper on my build or parts
#17 |
http://i1224.photobucket.com/albums/...fter/018-1.jpg
tear down pics surprise!!! hell yea the heads already ARP studded ! |
#18 |
tear down pics
http://i1224.photobucket.com/albums/...fter/018-1.jpg http://i1224.photobucket.com/albums/...fter/012-1.jpg hell yea!!! surprise! the head is already ARP studded! and it looks like the timing chain and guides are all new! |
#19 |
whst do you guys think of this?
ACT 600230 XACT ProLite Lightweight Flywheel 10.5lb 89-98 SR20DET any of you running a light weight flywheel? |
#20 |
ok just plasti gauged my rode bearings came out with this is this an ok range? i read that nissan specs is .0014" +/- .0004 so is this ok or is the plasti gauge off???
#22 |
Ok quick question I knw max ring gap is .39mm I got me some wiseco forged pistone heads and the ring gap is at .43mm will I be ok or should I bore to 86.5mm or 87.mm
