Old 02-17-2020, 06:42 PM   #1
ronnieronron
ronnieronron is on a distinguished road
SR SR20det Lost Shim? Help?
Hello everyone, i broke a rocker arm on cylinder #2 exhaust side. with that being said. both shims popped out. I found one. Non guided shim. Im having a difficult time finding the other one.
Any suggestions where i should look before i pull the oil pan?
Thanks
ronnieronron is offline   Reply With Quote
Old 02-17-2020, 07:05 PM   #2
S14rebuild
Its either in the head or found its way into the oil pan....id be more concerned with that valve through.......
Old 02-18-2020, 09:33 AM   #3
TheRealSy90
TheRealSy90's Avatar
90% of the time they fall down into the oil pan. Just check and double check every nook and cranny inside the head again before you run it. The shims are good at hiding in there.
Such a good signature.
Old 02-18-2020, 10:53 AM   #4
ronnieronron
As far as being bent?
or how.
Also it sounds like im going to look a little harder and then drop the pan i guess
Old 02-18-2020, 11:18 AM   #5
S14rebuild
or how.
Yes being bent just a precaution....
Old 02-18-2020, 12:09 PM   #6
ronnieronron
understood. I compression test also. and let you guys know. appreciate the input
Old 02-18-2020, 12:30 PM   #7
S14rebuild
Kool good luck on the search and fingers crossed for a health motor
Might wanna look into dual guide shims now....never worry bout thrown rocker again
Old 02-18-2020, 01:55 PM   #8
ronnieronron
yeah i think im going to do that. my friends dad is a machinist so thatll help
Old 02-18-2020, 01:57 PM   #9
S14rebuild
Dam, must be nice, did mine with a dremel lol
Know lots of people in mylife that could help me with alot...still waitn to meet a machinist lol
Old 02-18-2020, 03:19 PM   #10
ronnieronron
i was curious how some people did it. i guess dremel might be the most budget. haha.
again thanks for the insight guys
Old 02-18-2020, 03:44 PM   #11
TheRealSy90
I've done multiple dual guide mods using my old bench grinder. The popular "dual guide mod" video I made years ago is on youtube and I still use that same grinder.
Old 02-19-2020, 08:21 PM   #12
ronnieronron
No luck in the oil pan
There was also no metal shaving in the filter or at the bottom of the pan. :/ im going to keep looking it was getting dark and maybe more sun might help
Old 02-19-2020, 08:22 PM   #13
ronnieronron
Wasnt sure how to multi quote
