![]() Join Date: Sep 2014
1992 Nissan 240SX Coupe
Hello, I am posting my car up for sale at $4800. My car has the original "super white" paint, and is a 5-speed manual. The car has a clean title under my name, passed smog and it is already registered for 2018. The car is mostly stock with 100% full interior and has a rebuilt motor. It was rebuilt by the previous owner in his own shop. I do not have the paperwork for it. It is a S14 KA24DE. The motor runs without any problems. The chassis has 199,212 miles and the engine has about 14,000 miles. There is no mechanical issues with the car. The transmission runs smoothly and does not grind. The chassis is clean and does not have any rust or damage nor been in an accident. The AC is there and is recharged but the belt is missing so it does not work for now. I have the belt just do not have the time to install. It blows freezing cold and was barely used when I had it working (receipt provided if requested). The car has power windows, automatic seat belts, power sunroof, door lock actuator (automatic locks), and power adjusting mirrors. The only issue with the car is cosmetics and small electrical stuff. The car drives really well and is very smooth. It idles perfect and has a tight/responsive feel to it. This car is really an excellent daily driver and is reliable. I will not be selling the steering wheel with the car. I will install stock steering wheel or you can bring your own if you'd like. I do have A TON of extra spare parts that I will throw in as well. Overall the car is very clean and is a complete. A lot has been done to make the car a more solid, dependable car. You can contact me by email, PM or text me at (805) 551-611eight ! I can provide more pictures upon request. My name is Jon, thanks. COSMETICS: -tiny rip on driver side door panel -dents in driver side fender -small dent on the trunk -minimal scuffs/scratches exterior of car -dash has two cracks ELECTRICAL: -reverse lights do not work -driver side seat belt sometimes retracts back ENGINE: -rebuilt S14 KA24DE -egr delete plate -Mishimoto aluminum radiator -Mishimoto electric fans -Walbro 255 fuel pump -Catco high flow catalytic converter 3" -Xspower dual exhaust 3" with resonator delete -NGK spark plug wires -NGK iridium ix spark plugs -NRG 3 piece cooling panel -Circuit Sports aluminum overflow tank -Circuit Sports bmc stopper -ISR silicone radiator hoses upper and lower -ISR thermostat -new OEM water pump -new OEM distributor -new OEM distributor cap and rotor -new OEM clutch master cylinder -new Z32 fuel filter -new fuel lines -new power steering lines -ebay intake -stock everything else DRIVETRAIN/SUSPENSION: -Powered by Max competition coilovers 8k front, 6k rear (will come with 10k springs as well) -ISR pro series rear upper control arm -ISR pro series rear toe control rod -Drift Freaqs engine mounts and transmission mount -Energy Suspension power steering rack bushings -Suspension Techniques front and rear sway bars -Circuit Sports front and rear sway bar end links -Tein inner tie rods -Circuit Sports pillow ball outer tie rods -Gktech steering rack spacers -Exedy OEM clutch with pressure plate -ISR short shifter v2 -Circuit Sports solid shifter collar bushing -Circuit Sports shifter return spring kit -P2M clutch release pivot ball -ISR stainless steel front and rear brake lines -Stoptech sport drilled and slotted rotors -Stoptech sport brake pads -Federal 595 evo 205/40R17 tires 90% tread -MST MT07 17x9 +20 wheels -Muteki SR48 lug nuts -ISR exhaust hangers -ebay 25mm spacers front, 20mm spacers rear -welded differential -stock everything else INTERIOR/OTHER: -S14 confetti driver and passenger seats -Tomei 90mm shift knob -new OEM turn signal switch -NRG slim hub -NRG wheel adapter -Nardi leather deep corn 350mm steering wheel -JBL GTO529 6.5" front and rear speakers -Version Select Racing checkered floor mats -P2M drift button -Sylvania Zevo LED tail light bulb -HeatShield 240SX sunshade ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
hey i am very interested in this car and i can have the money saved up in around 6 months or if ur willing to do payments so please lmk if u want to talk and work something out
![]() Join Date: Apr 2007
$4400 offered with steering wheel and meet me half way...
http://zilvia.net/f/traderratings.html?u=57636 If i sold you something or gave you it for free post here! Thanks! |
#9 | |
Www.PowerAutosports.com |
Tags |
240sx, coupe, nissan, pop up, s13 |
