1992 Nissan 240SX KA-T with Silvia FRONT END
Location: Lawrenceville, GA Year - Make - Model: 1992 Nissan 240SX with Silvia FRONT END Price: $9,500 Title Type: Clean Contact: 404-723-0835 I've put a ton of work into this car and used to use it as my daily driver. This thing runs strong and has been VERY dependable for me in whatever I've needed it to do. For example, I had to drive down to Savannah, Ga a coupe times and then drove back to Atlanta with ZERO problems. This also has a PASSING EMISSIONS test, CLEAN TITLE, ZERO RUST and ZERO LEAKS so you are good to go. The Odometer has 255,xxx miles on it but the gauge cluster was replaced along with the dash prior to me buying it. And the engine has been rebuilt as well with ONLY 2,390 miles on the rebuild. I get looks and thumbs up anywhere I go with this thing, it's a real head turner. I'M NOT LOOKING FOR ANY TRADES, JUST CASH. *Like I said before I used to use this as my daily driver to go back and forth from work, run errands, ect. I have since then got a new vehicle and drive this about once a week. So the miles will not go up very much if at all. Everything runs great just keeping the miles low and garage kept for right now. ENGINE: -KA24DE-T Running 20psi (Rebuilt engine with only 2,390 miles)* -Biagio external wastegate turbo (Rebuilt with 2,390 miles)* -TIAL adjustable wastegate -Blitz blow off valve -PWR Intercooler -ARP head studs -New Cometic Street Pro steel head gasket -Forged pistons -Forged rods -Forged crank -JGY fuel rail & injectors -Stock head, cam, valves & springs -Stock intake & throttle body -NGK R5671A-7 spark plugs -Heavy Duty MSD spark plug wires -New water pump & thermostat -New Aluminum coolant tank -Power steering cooler -Mishimoto radiator -New belts -Re-sealed front cover & oil pan -MSD blaster2 coil -New Optima Yellow top battery (Relocated to the trunk) -Megasquirt MS2 stand alone ECU (With an excellent tune on it currently) -Polyurethane motor mounts DRIVETRAIN: -JGY light weight flywheel (Resurfaced) -New ACT NX4-HDR6 clutch (2,390 miles on it)* -SR20 transmission w/ Amsoil (43,xxx miles with fresh fluid since the engine rebuild) -New Megan Racing short throw -Limited slip diff w/ Amsoil (Fresh fluid since the engine rebuild) -Polyurethane transmission mount WHEELS AND TIRES: -Continental Extreme Contact DW tires (2,390 miles)* >235/45R17 Front >255/40R17 Rear -XXR 535 wheels (2,390 miles)* >17x8.25 Front >17x9.5 Rear SUSPENTION: -Nissan Sumitomo 4-piston front calipers -Oversized rear rotors -Sportline 85173 springs -Adjustable struts -Adjustable front tension rods -Adjustable rear upper control arms -Adjustable rear toe rods ADDITIONAL GOODIES: -Silvia front end -Silvia S15 steering wheel -Silvia S15 Shift Knob -S14 seats -Power window conversion -Custom exhaust with electric dump(So you can go open and loud or closed and silent with a push of a button) -Python 5303P Alarm System -Smoked tail lights -Working Power steering -Working JDM Climate control (A/C went out but tested it and it is only the compressor, so change that out and you'll be good. Heat is hot and works amazing though!) -Xenon headlights -Innovate LC-1 air/fuel gauge -Autometer Gauges: >voltage >oil pressure >oil temp >fuel pressure >vac/boost >pyrometer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Forged crank? Details?
MRP Manufacturing |
