12-06-2017, 10:52 PM | #1 |
Rb20 Questions and Help
Hey guys I’m in the process of building a rb20 for my s13 and I’ve got a few things piled up already, I just need help with on what else I would need to get to complete it. Thanks advance! The power output I was hoping to get is between 350 to 450 whp. And if I can make more with what I have so far that would be great. What trans would be best to go with? Which turbo? Which Big brake setup? Rear end? And to lay that power to the ground I have 18x10.5 for the rear and 18x9.5 in the front wheels. This is a car that I will hopefully complete for street use once in a while not as much a daily. And I will be sending the block and head to a machine shop to have that all re done.
Parts I have... -T4 Top mount manifold (unknown brand) -Tomei Exhaust -Haltech Ecu -Cp forged pistons 80mm 8.5:1 ratio -Spool H beam connecting rods -ACL +0.025mm Race bearings -Nitto Extended Crank Collar -N1 Oil Pump -Tomei Exhaust and Intake cam gears -Kelford 272/278 cams with 10mm lift -SuperTech Valve spring set -SuperTech +1mm intake and exhaust valves -Aeromotive FPR -Arp headstud and main studs -z32 fuel filter -Idx 1050cc injectors -Garret Boost gauge -Walbro 400lph fuel pump(e85) -Mishimoto Oil cooler -Cx racing fmic |
