Old 06-08-2017, 08:22 PM   #1
doridoridori
doridoridori is an unknown quantity at this point
Shifter snap ring question (SR trans)
So with the engine/trans I recieved, the shifter came without the shift knob and it had the rest of everything. It came with a snap ring that goes in the groove when the shifter is in place. I'm not sure if the ring that came with it is original or not but when I put it in the groove I can do it by hand without compressing the ring and it fits in the grove then after moving the shifter a little bit it comes out of place. Does anyone know a part number or can i get another one of these snap rings at any parts store? it seems smaller than it should be the way it comes out of place.
doridoridori is offline   Reply With Quote
Old 06-08-2017, 08:39 PM   #2
Percy
Percy is an unknown quantity at this point
There are 2 different snap rings needed. Sounds like you need the one that holds the shifter cup in place, which is the first part number below.
RING-SNAP CONTROL LEVER - 32204-V5004
RING SNAP - 32204-V5003
Percy is offline   Reply With Quote
Old 06-09-2017, 01:05 AM   #3
doridoridori
i see that makes sense then, i had a feeling something was either missing or this was the wrong size. You wouldn't happen to have pics of how it all goes in place do you?
Old 06-09-2017, 12:21 PM   #4
gaz_moose
gaz_moose is an unknown quantity at this point
if you take a picture of the bits you have I will tell you if you are missing any bits.
gaz_moose is offline   Reply With Quote
Old 06-09-2017, 06:33 PM   #5
doridoridori
dang already left the shop but it looks like everything is there except for the first part number you gave me, it'll be here tomorrow much appreciate the help!
