07-01-2015, 07:23 PM | #63 |
Glad you're in, thank you!
yes sir j30 compressor. I dont have a problem doing hoses for a different compressor but I currently only have hoses/fittings for the j30 configuration. I am also looking into doing a tucked rad/condenser combo so that you can run a shroud + 2 fans in puller configuration, however I'm not sure if things are going to get too expensive at that point. Calling my radiator place tomorrow to see what they can come up with. |
07-05-2015, 01:46 PM | #69 | |||
got you down! thanks! Here is a rough list of everyone who has shown interest in the kit. I've tried to include all the info pertaining to each car. The only kit I can make quickly right now is the 95-96 s14/j30 compressor combo. If anyone is able to confirm that the s13 engine bay dimensions are the same, then we are good to go for s13/j30 setups as well. I do not have a problem doing other setups and including them in the group buy for better pricing, however I will not be able to build your exact kit as fast and will need help from you to finish your hoses. Anyone I've missed please just let me know, I've tried to include all of you who PM'd me as well. I intend to build these kits as fast as possible as I know its not getting any cooler out there. Looking at a two week ship time MAX, clock starts ticking the day you order. Thank you all for your interest. Group Buy: alexisonfire whatbrokethistime (rb26 s14) greenmachine300zxtt (rb25 s14) fd94 (1jz s14) Potentially Interested: projects14zenki Mr.Slipngrip usrocket (rb26 s13 w/rb25 compressor) reddrum13 (2jz s14) redline_racer510 (rb25) EnemyS15 JRex(1jz S13) civicEJ8 ProJNightshade (rb25 s14) jduke (rb20) 1jz_s14 (1jz s14) Ramonesfreak2010 (sr20 w/ka compressor) EJ8_944 (rb) owinbush (rb20) SugarMomma_money(sr20) PeaceOnesxWai (s13 ka) Waiting for potential tucked radiator option: max1008 MR_GUTTI (rb25 s13 + chasebays rad) Last edited by alex_s817; 07-06-2015 at 08:34 AM.. |
07-06-2015, 01:02 AM | #73 |
Trader Rating: (34)
Feedback Score: 34 reviews
Ive always wanted to do a custom AC hose/condenser set up. Your set up turned out great.
If you do a S13 w/ KA compressor lines id be interested in the group buy. |
07-06-2015, 08:40 AM | #74 | ||
switched you over on the list, thank you!
thanks a lot! Given all the interest I've had, s13 with KA hoses looks like it will definitely be a thing. Ill update as soon as I know for sure. |
07-06-2015, 10:09 AM | #75 |
Will the J30 bolt up to an RB25/RB26 compressor bracket? My NEO is an r34 RB25. Running a griffin radiator And dual pushers which i probably have to mount to the condenser now right? Will blow through both.
Also, does this come with a smaller receiver / drier? Do the lines run from the compressor through the front hardline and through condenser and out the passenger frame rail up to the firewall? My interior is completely gutted so I'll probably end up doing some 90 degree fittings inside the firewall and making something custom. |
07-07-2015, 10:41 AM | #77 | |
The drier is integrated into the condenser, which is honestly one of my favorite features of the kit. It was much harder to make the mounting brackets but the cleanliness of an integrated drier was worth it for sure. The high pressure line runs out of the condenser and 180s to run underneath it. it then pairs with the other low press hose and they route together along the pass side frame rail. I did it this way rather than behind the engine because I wanted it to be as clean and undetectable as it could be, meanwhile still allowing for as many turbo kit options as possible (given the compressor space is there) Regarding your interior, there are a few options out there if you are looking to run an aftermarket evaporator/heater core unit. Vintage Air out of Arizona has some really cool stuff, and although it's pricey, it allows you to save a ton of space under the dash. I am running one in my turbo truck build and with the different options for hose routing, you won't be able to see any lines in my engine bay, aside from the compressor where they need to hook up. Of course if you were to run one of these setups, the hoses included in my kit wouldnt need to have the OEM fitting adapters. |
07-07-2015, 10:44 AM | #78 |
Fortunately I was lucky enough to pick up and entire s13 front core support from a friend last week, so testing for fitment wont be an issue! Waiting on the new condenser brackets from the water jet place and I can verify for sure that everything fits up.
07-07-2015, 09:05 PM | #80 |
I have the old version 24"x10"x3". Two of the 3"sits under the core support so I have an inch toward the engine. I'm using the stock clutch fan. Contact me if you have any questions. Thanks!
07-07-2015, 09:17 PM | #81 | |
Awesome, thanks for the explanation. I am using the dual 12" flex - a -lites as pushers. I could do that vintage air kit and it would be kick ass. My dash is gutted and I'm running a switch panel. I can run that unit in place of my glove box. |
07-11-2015, 09:53 AM | #83 |
Hey guys, take a look at this and let me know what you think. My car is gutted behind the dash so I'm looking at an option for AC only.
This universal evaporator would work with some 2.5" flex hoses to my vents. Question is, are all the AC hoses a standard size? I could get the lines in this kit made a little longer and mate it right to this unit. ImageUploadedByTapatalk1436629948.061033.jpgImageUploadedByTapatalk1436629958.941382.jpgImageUploadedByTapatalk1436629967.527088.jpgImageUploadedByTapatalk1436629974.807927.jpgImageUploadedByTapatalk1436629982.158794.jpgImageUploadedByTapatalk1436630002.250124.jpg |
07-11-2015, 11:58 AM | #84 | ||||
07-21-2015, 10:36 PM | #88 |
Got me interested. I want you to work on my car sr20det needs a/c. S13uploadfromtaptalk1437539754307.png
07-21-2015, 11:02 PM | #89 | |
This thread is for swapped cars listed above, SR in a 240 can be done with factory parts, no swap kit is really needed |
