09-17-2010, 04:02 PM | #121 | |
09-17-2010, 10:40 PM | #122 |
Just got in my Steering overhaul package.
(I already got some Moog Outer Tie Rod Ends)
09-18-2010, 09:23 PM | #125 |
Thanks Guys ^^
I believe in doing it right the first time with quality parts Got everything installed today, I would have kinda done a step by step but didnt think about it at the time A BIG noticeable difference after everything, Steering is much more responsive and stiff. The Tein Tie Rods came with steering angle spaces. I must say i never expected that a 1/4in metal ring would make such a noticeable difference in steering angle yeah a def need to get some Angle adjuster tie rod ends
09-19-2010, 02:14 AM | #126 |
the tein tie rods are dope hey. i've got the same in my car
i took my car for a spin today and tested my turning radius , i was laughing the whole time. you basically turn and your inside rear wheel is pretty much stationary
1992 240sx (RB20. 362whp@16psi) |
09-21-2010, 10:15 PM | #127 |
M an your build looks exactly like mines with the exception of the new oilpan. Man i have been looking for the P/N for the front timing cover for like a week thanks for the info. I will post pics as soon as i get my timing cover and rocker covers in.
Think "satin wrinkle black" |
09-26-2010, 02:06 PM | #129 |
nah man its still happening.
I had to wait until my wifes GC interview in New Orleans before taking the next step. Im iffy on my wiring harness so Im gonna send it off and have it checked over before pluging it in. But I will start pulling the KA and dropping the RB in when it starts cooling off, or within two weeks
09-26-2010, 08:16 PM | #130 |
so anyone know for a fact or have pics if its possible to put the FAL fans on the Koyo Rad as pullers with Syko Mounts, WITHOUT cutting the Upper Core Support?
Im kinda not wanting to sandwich it behind the condenser, thinking it might not be efficient enough
09-27-2010, 01:30 AM | #132 |
Dunno if it'll fit with your fancy condenser but with the stock one on an S14, you will be able to barely fit a clutch fan by just bashing the upper core support a bit if any.
09-27-2010, 03:14 AM | #133 |
I had to cut my upper core support and drill new holes to move the radiator forward enough for the fan clutch to fit with my Koyo. Mckinney mounts.
95 240sx RB20 415whp 91 Nx2000 VVL yo |
09-27-2010, 08:26 AM | #134 |
^^ that looks good but damn its missing a lot of the support. Could it be possible to obtain shorter radiator that would fit underneath the core support as if it was tucked in forward?
09-27-2010, 03:12 PM | #135 |
Ugh. So true. Im about to give up and take mine out. As of Friday I can no longer keep it cool with all the AC crap.
I want to put in my clutch fan so bad but I do not want to cut my rad support at all. Im on ZeroLift mounts and there is not much space. Even my E-fans are mm's from my pulleys. |
09-27-2010, 03:44 PM | #136 |
Yea Rb's and cooling dont get along so well. I use pusher fans SO FAR so good. I'm with Obee i would hate to cut my support.
Nothing says racecar like a stock car with no interior. |
10-03-2010, 07:26 PM | #137 |
sileighty85 Im debating the exact same thing and what I am leaning towards is the flexalite 106-398( these things are supposedly 1 3/8" thick). I'm thinking of mounting 2 of these in front of my condenser and fabbing up a piece of plastic that seals up the area around both of the fans to draw in the air while the car is at a stop and possibly a smaller fan on the other side that is controlled through a switch. I heard not even the FAL fans fit properly so upon reading about many other peoples setup the front pusher setup sounds ideal to me.
10-03-2010, 07:49 PM | #138 |
Hmmmm.....you guys got me 2nd thinking the route I went with my fan setup. Since I live in the desert.....here in AZ, i ended up wiring up 3 mishimoto fans.
2 pushers (in front of the radiator) 1 puller (behind the radiator) -The puller is always on. -1 pusher is wired to turn on when the temp gauge needs it to -Other pusher set up for when I use AC Is this not an optimal/ideal setup?....should I have gone with the 2 flex-a-lite fans instead? Sileighty, I just recently found out about the pre-made wire harness conversion done by Yuri. I am in the same boat as you.....waiting for the RB25 S2 into a S14 chassis. Have you heard anything else from him? I want to get this pre-made harness asap....but dont want to wait another 2-4 months. BTW....this is a great thread....keep up the excellent work! Elmer |
10-03-2010, 09:03 PM | #139 | |||
Shit man if it works Id keep it. Quote:
I'll be sending my harness I "Repaired" and "Converted" to Yury to have him inspect it, since the harness was so hacked up. If i had an unfucked harness Id probably trust it but dont wanna risk frying my ECU
10-04-2010, 12:53 AM | #140 |
Hey pat how have those isis arms been holding up for you?
Small freaking world dude, chit chatted with a guy and his wife this weekend that said he was from Shreveport. I asked him if he knew you and the dude couldn't belive I knew you haha. I forgot their names but they were pretty cool. He said he was doing a rb vert, sbc hatch and a few coupes. |
10-04-2010, 01:00 PM | #141 |
Thats what me and my friend did to our wiring harness for both the s15 sr and my s1 RB he seems like a pretty knowlegeable guy and plus me and wiring harness modification work dont get along,lol.
10-04-2010, 11:03 PM | #142 | |
I dont know anyone doing an RB vert, but it might be this one kid i know up here. Not sure if its actually gonna happen though. From what Ive heard hes had quite a few projects that havent worked out all that well. do you know if it was an RB 20 or 25? Yeah ive done quite a good bit of bussiness with Yury, Been happy with every product and very helpful to boot even at 10:00 at night
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 10-22-2013 at 09:09 PM.. |
10-08-2010, 08:39 PM | #143 |
So i finally got in my Hyper Gear Turbo
I wanted a turbo that bolted up to the stock exhaust and down pipe since i spent a good bit on the SYKO mount set. Not looking for 500hp just somthing more than stock so this turbo will do just fine Key benefit: 360 degrees Thrust bearing Heat treated steel wheel and shaft Suitable for High Boost applications Product Goal: High Responds, High Torque. Long life time. OEM Bolton RB25det Upgrade. sure i sacrifice the stock Ball Bearing system but now i got a rebuild-able turbo Comparison between the Stock R33 turbo and the Hypergear R33 Turbo Stock Hyper Gear Most noticeable difference is the Exhaust Wheel The craptasic Ceramic wheel is replaces with a Steel turbine wheel Stock Hyper Gear Ive been sick for the last 3 days but if i feel better I will begin pulling the KA on the S14 tomorrow
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 10-08-2010 at 09:58 PM.. |
10-08-2010, 09:40 PM | #144 |
If you dont mind me asking, how much was that turbo and where'd you get it from? I've been looking into one of these for my rb25. Also how much hp is this one rated for?
10-08-2010, 09:45 PM | #145 | ||
Conversion is moderately priced, Shipping is what pushes it over the top. It would be about $200 total in shipping since they are located in Australia. Instead of sending my turbo to them they were able to locate a R33 turbo over there for the same price that it would cost to ship. So im able to keep the turbo an rock it if I were waiting on it to come in. Quote:
10-09-2010, 09:54 PM | #147 |
Alright guys Stage 1 is complete!
Finally had some free time to pull the engine hmmm KA48 Hmmm what else needs to be taken out ahhhh finally Time to Power Wash So after the engine bay is cleaned and IC piping Preped then I can drop the RB in. Hopefully I can do it next weekend depending on how my work week goes
10-10-2010, 05:43 PM | #150 | |
Indeed I am I cant wait to hear this baby roar
Mainly been waitin on parts and a wire harness
rb25 install, rb25 rebuild, rb25 s14, rb25 swap |
