03-16-2008, 11:38 AM | #1 |
Engine Vibration at 4k+ RPMs
For the past few years I've been running some solid motor mounts that basically look like these
Same material for the tranny mount. So everything that goes on I can literally feel. I can feel a vibration difference in knock from 91 octane to 100 octane. Now my problem is that ever since I went to these solid mounts I've been having a harsher than normal vibration from 4k+. There isnt any power loss and its directly from the engine and since I'm doing maintenance on my car I thought I'd try to tackle this problem since it's been bugging me for the past 2 years. My wideband isnt showing any dips/spikes at 4k and my SAFC isnt showing any knock either. Its constant within all 5 gears which makes it unbearable to drive faster than 85 mph in 5th gear. I dont believe anything is loose, I've upgraded/replaced/removed/re-installed most of the exhaust/turbo components within the past 2 years and still the same vibration. My assumption would be that RAS would help, what should I do? |
03-20-2008, 02:31 PM | #2 |
Trader Rating: (22)
Feedback Score: 22 reviews
I don't know why yours is doing that but my SR has a horribly loud rattle in the exhaust at 4k RPM. I don't think its a performance related issue but more so that something is loose or broken and the SR makes it apparent at 4k because that must be a resonant frequency of the motors sound.... Kinda like when everything in your interior vibrates a bunch at a certain RPM.
This may be totally wrong but it sounds good. Now if I can only figure out what the fu*k that noise is!
Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
03-31-2008, 09:36 PM | #3 | |
shit i thought i was the only one who had that problem |
04-05-2008, 05:59 AM | #4 |
yea could be the resonates...or that youre solid motor mounts are transfering all the engine vibrations. try either changing to a diffrent muffler to change the pitch on the engine, or go back to rubber or urthan engine mounts.. also look to see if youre transmission is touching anywhere. i had that problem in my sonoma and it pretty much rattled the whole cab at certain rpms
