Old 10-11-2018, 01:54 PM   #1
cpl dozier
cpl dozier is an unknown quantity at this point
1992 S13.5 LS Turbo
Please read entire listing before commenting.
1992 Nissan 240sx
Exterior:
S15 Front Origin Bumper
S13.5 Front Fenders Fiberglass Origin 40mm Wide
S15 Vented Seibon Hood
S15 Headlights
Rear 50mm Fiberglass Origin Over Fenders
Origin Side Skirts
S13 Origin Rear Bumper
Nismo Carbon Fiber Wing
Seibon Carbon Fiber Hatch w/Lexan Glass
New Metallic Blue Paint
Smoked Tail Lights
HID Hi/Low 6k Headlights
Square Wheels 18x9.5+12mm 4x114.3 Pattern
Nexen Tires Front 245/30/18 Rear 275/30/18
Aluminum 25mm Wheel Spacers w/Extended Studs
CX Racing Coilovers
Megan Racing Rear Upper Control Arms
Megan Racing Lower Traction Rods
Interior:
Formula Drift Spec Rollcage
Vinyl Wrapped Custom Aluminum Door Panels
Dash with vent holes filled (except defrost top vent) vinyl wrapped
Autometer Gauges: Speedometer, Tach, Voltage, Oil Pres., Coolant Temp. Boost
AEM Uego Wideband
Black vinyl racing seats
RJS 4 pt. racing harness
Turbosmart Boost Controller
Grant Steering Wheel w/Quick Release
15 Gallon Fuel Cell
New Battery
Engine built by Mike Lough Racing:
5.3 LM7 Cast Block Bored to 5.7
364 LQ4 Crankshaft w/Polished Journals
6.125 Callies Compstar Rods
King XP LSX Bearings Rods, Main, Cam Bearings
New GM Cam Retainer Plate
New GM LS9 Head Gaskets
New GM Lifter Trays
New GM LS7 Hydraulic Roller Lifters
Wiseco Forged Pistons w/Rings
Block Water Jackets Filled
Balanced Rotating Assembly
Engine Break-in on Stand
Brian Penn Racing Oil
Internal Oiling Mods for Forced Induction
ARP Main Studs
Comp Camshaft Custom Grind
New GM Pushrods .080 wall
New GM Double Roller Timing Set
Holley Sniper Intake Manifold
Holley Sniper Fuel Rails
FIC 95# Injectors
Fast 102mm Throttle Body
Holley Dominator Fuel Pumps
Holley Fuel Pressure Regulator
MSD Plug Wires
Hooker Ceramic Turbo Headers
Custom Exhaust Turbo Cross Over Pipes 2.25" into Y @ 2.5" into turbo inlet @ 3"
Knife Edged Turbo Inlet
All Piping Ceramic Coated and Heat Wrapped
Borg Warner S480 Turbo 1.32 A/R
Turbo Exhaust Housing Machined from 5" v-band to 4" v-band
Turbo Guard Grill
4an Turbo Feed line with Summit Check Valve
10an Turbo Drain Line with Summic Check Valve
Custom Aluminum Turbo Oil Sump
Turbowerx Exapump Oil Pump
CX Racing 1000hp Intercooler
Griffin Aluminum Radiator
Electric Fan
Tial MV-R Wastegate
Tial Q BOV
Mishimoto Stainless T Bolt Clamps
Mishimoto Couplers
New 180 Degree Thermostat
8an Fuel Feed / Return Lines
New LS1 Power Steering Pump
New LM7 5.3 Silverado Alternator
ICT Billet High Mount Accessory Bracket Kit
Summit Racing Valley Cover and Knock Sensor Delete
Earls Steam Tube Kit
All Fittings and lines from Fragola
PSI Conversions Wiring Harness and PCM
Custom Turbo Mount
Turbo Blanket
Custom Plate Motor Mount
Wilwood Clutch Master Cylinder
Chase Bays Clutch Master Cylinder Line Kit
Chase Bays Hydro Hand Brake (Not Installed)
Sikky Clutch Adapter Plate
Monster Stage 5 Clutch
Steel Resurfaced flywheel
Built T-56 Transmission with Viper Ratios
Hawk Racing Billet Shifter
Custom Transmission Mount
Sonnax Slip yoke
Custom Aluminum Driveshaft
Tomei Technical Trax 2-Way Differential
Car makes over 1000whp on Q16 and 20psi (Could do it on Pump gas)
Street tuned at 93 Octane and 10 PSI at 622whp. Super Conservative
Made 485whp N/A
Entertaining Trade Offers. Cash is King. Looking for 20k obo. Don't like the price keep moving. This car is a 6 year build with lots of time and money invested. No Heat or AC at the moment. No known issues. Probably 1000 Miles on the car since built. Everything replaced. Clean Title in Warrior, Alabama.
Watch the video for walk around and to hear run.
https://youtu.be/NZYiTLsNU4o
Serious inquiries please message me for further details or pictures of specifics.
https://youtu.be/rM7e4A50Y4k
cpl dozier is offline   Reply With Quote
Old 10-12-2018, 12:52 AM   #2
ReallyWantsA240SX
ReallyWantsA240SX is an unknown quantity at this point
Needs photos.
And dyno sheets to prove it makes 1000hp.
ReallyWantsA240SX is offline   Reply With Quote
Old 10-15-2018, 09:57 AM   #3
bluz370
bluz370 is an unknown quantity at this point
I would be willing to offer 15k on this, if you are accepting offers, please text or email me at 972-693-1491 or [email protected]
bluz370 is offline   Reply With Quote
Old 10-17-2018, 09:44 AM   #4
cpl dozier
Originally Posted by ReallyWantsA240SX View Post
Needs photos.
No...I don't. Thanks.
Best offer thus far is 15,500...Serious inquiries message me.
Old 10-17-2018, 03:30 PM   #5
PAPERPLANES
PAPERPLANES's Avatar
PAPERPLANES is an unknown quantity at this point
I could give two shits about what you claim your car makes, dyno sheets or GTFO.
PAPERPLANES is offline   Reply With Quote
Old 10-17-2018, 04:39 PM   #6
BoostedBucket
BoostedBucket is an unknown quantity at this point
Just because his license plate is 1000HP doesnt mean hes claiming the car makes it. Clearly states hp numbers and they dont seem too out there for the setup he has.
Good luck with the sale.
BoostedBucket is offline   Reply With Quote
Old 10-24-2018, 09:47 AM   #7
greddy2die
greddy2die's Avatar
greddy2die is an unknown quantity at this point
Send a message via AIM to greddy2die
Good luck with the sale man, sounds good & price seems very fair. Some people really dont understand turbo LS motors & their HP capabilities on what they may believe is "a little" boost lol
greddy2die is offline   Reply With Quote
