Old 05-13-2013, 10:04 PM   #1
89_SR20
89_SR20's Avatar
89_SR20 is an unknown quantity at this point
s13 Crankshaft Seal Little Metal Wedge?
Im in the process of replacing my Crankshaft seal on my Redtop SR20DET. But I noticed this little metal wedge looking thing, (Like a half moon) What is it? I assume its needed but I don't know where it goes. I looked throught my FSM and found nothing in there regarding it.
89_SR20 is offline   Reply With Quote
Old 05-13-2013, 10:12 PM   #2
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
there should be 2 of them on the front of your shaft, there are little cut outs for them on the shaft. they are to prevent your oil pump spacer and crank pully from spinning on the shaft... very important to reinstall...
Drift_FX is offline   Reply With Quote
Old 05-13-2013, 10:28 PM   #3
89_SR20
89_SR20's Avatar
do you know the part number for them, I only have one and I don't know if the other one is on the shaft, I looked at my spare SR and it doesn't look like it has them either... And its as easy as pulling the crank shaft pulley off and re-installing them right? Now all I need to do is find out what happened to the other one
Old 05-13-2013, 11:06 PM   #4
oni jake
oni jake is an unknown quantity at this point
There's only one on SR cranks. They are called wooddruff keys btw.
oni jake is offline   Reply With Quote
Old 05-15-2013, 12:37 PM   #5
quickdiversion
quickdiversion is an unknown quantity at this point
Also note... Its called a front main seal. The one on the back of the motor is called the rear main seal.
quickdiversion is offline   Reply With Quote
crankshaft, oil seal, sr20det 240sx s13
