Old 11-30-2014, 01:49 PM   #1
Jboob
Jboob is an unknown quantity at this point
s14 Legenfelter S14 240SX (not your typical swapped 240)
What’s up everyone. I am looking to sell my very special 1995 Legenfelter swapped 240SX. This is not your typical LS swapped 240. I have over 10k in the engine build alone that not including the engine itself. There is over $45,000 if not 50 into this build I am just ready for something like a C63 AMG, CTSV, or an M3. I was on active duty in the USMC but I am in college now so I don’t have the money to build it to my 1000hp goal. The engine is built to handle over that the tranny is good to 700+. This truly is a once in a lifetime car. I personally wouldn’t drift the car but it is set up for drift right now. I more or less turned a racecar into a show car. Zero rust and a perfect dash everything on the car is flawless. This car will seriously make you famous. I was on the verge of getting sponsored but school got in the way and I just don’t and won’t have time for this beauty for the next three years or so. The car is far to nice to just sit around and do nothing while I go to college and work part time. Someone needs to buy it and show it off. I can get receipts for the engine build upon request. This car has the potential to make it into magazines. It draws crowds no matter where I go. The smart phones come out when I roll out. If I don’t get something like a C63 AMG then the money is going to pay off debt. I wouldn’t sell this car unless I truly had to.
Located: Lexington, Ky
Title: Clean as can be!
Mileage: 100xxx on the chassis and about 1.2k on eng since the build
Sale: $30,000obo (just a number I am starting at considering the amount of money in this car but I am realistic and know I will never get back what I have in it. I am open to offers)
Trade: Possibly. M3s, C63 AMG, CTSV, Corvette Z06
VIN: JN1AS44D4SW002386
Willing to ship! Serious offers only! Will not respond to low ballers and ridiculous trades.
Text (preferred, I get busy sometimes) or Call 719-231-710two- Rich
So here are the details. I’m sure there's more but I forget considering the amount of work done to the car:
Chassis/Suspension
95 SE
OEM keyless entry
ABS
Original imported from Japan Supermade Instant Gentlemen body kit
Re-sprayed oem 95 red (when I had the fenders pulled and stretched)
Custom LED front turn signals
Dmax coilovers NEW w/ about 5k highway mi
Front Godspeed tension rods (much stiffer and more angle than my old teins)
Front Godspeed Lower control arms (I went with Godspeed because I have seen them in action and take a beating. The build quality is far beyond all the tein stuff I had on there)
Front strut bar, unknown brand
Rear sway bar, unknown brand
Rear SPL upper control arm
Rear PBM toe rod
Kaaz 1.5way rear diff
20% tint on rear 3 windows
Pulled and stretched front and rear finders to fit the sickest of wheels
Engine
A rare 2000 ASA Lingfelter 5700 series (LS1) crate engine #63
Its been fully built to hold over 1000hp
550+ hp/trq to the crank.
Roughly under 10k miles on engine since new and 1.2k since the build
Great Circle track Lingenfelter heads
This engine is held back by the throttle body and injectors. Replace those and tuned can show over 600rwhp
2000 T56 6 spd out of Camaro
Custom Mounts
Hinson Long tube headers
Custom 3" to 2 Cats and Y piped toa Magnaflow muffler
Custom Driveshaft
Improved Racing custom oil pan baffle if you drift it, you won't starve it.
Brand new NGK Iridiums and Firewire wires
PRC custom 4 row Custom Radiator, it has no issues even sitting in traffic.
2 Flexalite Fans one pulls the other pushes
Upgraded power steering pump called a Turn1
Now for the good stuff!!
Three layer metal head gaskets
Manley Forged rods
Manley Forged bearings
ARP rod bolts
Wesico forged pistons
Weisco oversized rigs (for boost or bottle)
Factor balanced and polished crank
Ported polished heads
Honed and decked block
Honed and decked heads
Brian Tolley Stage three cam
Titanium double valve springs
Titanium push rods
Titanium lifters
ARP head studs
LS6 intake
Double chain timing chain
Fast fuel rails with 39lbs injectors
Monster stage three Clutch
Monster 18lbs flywheel
(I am forgetting things but it is FULLY built so if you think of something that would entail fully built it most likely has it)
Rollers/Stoppers
Z32 Fr Calipers w/ drilled/slotted rotors and Brembo brake pads
Rear Project Mu "drift" series brake pads
Fr steel braided brake lines
Varrstoen Fr 19x9.5+12 Hankook v12 225/35r19 90% treadwear left
Varrstoen Rr 19x11+12 (I forgot the brand but new) 245/35r19 90% treadwear left
Interior
Black carpet
Dmax checkered front floor mats
Suede door panels, balck suede and black everything else
MOMO Race steering wheel
NRG carbon fiber quick release
Momo hub
JDM Bubble shift knob
Kenwood Head unit, forgot the numbers w/ usb cable in glove box
Pioneer 6" 2 way speakers
Sparco FIA approved racing seats
4 point FIA approved harnesses
Custom drives seat bracket
Custom passenger seat bracket with Sparco Mount
Custom matched Interior to match the racing seats hand stitched
Handmade door Inserts
Handmade shift boot
Handmade and stitched rear seat to match the racing seats
Broadfield Customs Custom hand made gauge cluster with
Custom made red Speed hut GPS Speedo
Custom made red Speed Hut 8k tach
Custom made red Speed Hut fuel gauge
Custom made red Speed Hut temp sensor
*Cons,
No A/C, removed the condenser and a/c lines
Not a big deal but Sunroof trim is wearing down
Brakes squeaky. Pads are good; squeaking from friction material
The gas gauge needs to be hooked up
The rear bumper got hit but I will have that fixed once I have a buyer or before just depending on if I can save up enough to get it fixed before hand so its not really a con just something I will do before I sell the car.
http://s1278.photobucket.com/user/ri...ll1/slideshow/
Jboob is offline   Reply With Quote
Old 11-30-2014, 06:57 PM   #2
tobroketobuildarealcar
tobroketobuildarealcar is an unknown quantity at this point
30k for a s chassis and only one pic posted in thread good luck lol
tobroketobuildarealcar is offline   Reply With Quote
Old 11-30-2014, 07:41 PM   #3
wasabiboi
wasabiboi is an unknown quantity at this point
He might have messed up on uploading.
Facebook link with red S14
wasabiboi is offline   Reply With Quote
Old 11-30-2014, 08:15 PM   #4
TomShanK
TomShanK's Avatar
TomShanK is an unknown quantity at this point
*previously wrecked s chassis
TomShanK is offline   Reply With Quote
Old 11-30-2014, 10:17 PM   #5
wasabiboi
Makes you wonder what people are hiding on less built/expensive cars.
Old 11-30-2014, 11:59 PM   #6
Z32TwinTurbo
Z32TwinTurbo can only hope to improve
^hahaha good luck selling it now..
Z32TwinTurbo is offline   Reply With Quote
Old 12-01-2014, 08:37 PM   #7
rb27dets14
rb27dets14 has a little shameless behavior in the past
I can't even bother posting how I felt about that price now!!! lol........
Quote Originally Posted by andresr20
ffffffuuuuuuuuuuuuukkkkkkkkkk HONDAS
rb27dets14 is offline   Reply With Quote
Old 12-02-2014, 02:32 AM   #8
dizzariot
dizzariot's Avatar
Trader Rating: (47)
dizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfection
Feedback Score: 47 reviews
If you really wanted to save money you'd sell this and drive a piece of shit old Toyota Camry, not a new Mercedes.
The mark of a true sucka: 'RARE JDM' & 'OLD LOGO NISMO'
dizzariot is offline   Reply With Quote
Old 12-02-2014, 05:55 AM   #9
Now I know whi he had no posted pics
Old 12-02-2014, 08:32 AM   #10
sweet89s13
sweet89s13's Avatar
sweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura about
photos from photobucket posted taken by potato
SHIFT_SLIDE
sweet89s13 is offline   Reply With Quote
Old 12-02-2014, 09:43 AM   #11
Paradoxx123
Paradoxx123 is an unknown quantity at this point
I'm sorry but people need to take notice you are investing your money in a 20 year+ car and the money will not be gained back maybe not even half once you reach a specific point its almost pointless unless you are simply building your dream car but you cannot expect to get back what you put in it. You know what you can get for 30k~ (Even OBO)? Buy a brand new BRZ off the lot sure it may not be the best performer but its a 0 mileage 1 owner (you) car. Sure an s chassis is nice but its 20 years old...idk correct me if I'm wrong?
Paradoxx123 is offline   Reply With Quote
Old 12-02-2014, 10:56 AM   #12
nissanxrma
nissanxrma is an unknown quantity at this point
Godspeed and varrstoens for 30k? Phewwww
1986 Z31 - VG30ET GT30R
nissanxrma is offline   Reply With Quote
Old 12-02-2014, 01:14 PM   #13
Did any one notice the cons list
Old 12-02-2014, 01:25 PM   #14
Sr20SilviaS13
Sr20SilviaS13's Avatar
Sr20SilviaS13 is an unknown quantity at this point
A 30K car has godspeed parts. Sweet fucking christ. Im broke and dont buy that shit. Just part it out and be done with this joke of a for sale thread.
I do motor swaps in exchange for lunch.
Sr20SilviaS13 is offline   Reply With Quote
Old 12-02-2014, 02:44 PM   #15
Hacker
Hacker is an unknown quantity at this point
Take $29,500 cash??
J/k
Hacker is offline   Reply With Quote
Old 12-02-2014, 03:25 PM   #16
arandomrefrigerator
arandomrefrigerator is an unknown quantity at this point
http://ls1tech.com/forums/lsx-parts-...ne-t56-fs.html
LINGENFELTER
First he says legenfelter, then lingfelter.
Yes I'm a grammar Nazi.
arandomrefrigerator is offline   Reply With Quote
Old 12-02-2014, 08:36 PM   #17
turbo_dreams
turbo_dreams's Avatar
turbo_dreams is making a name for him/her selfturbo_dreams is making a name for him/her self
We're all being trolled.
www.tm-spl.com
Kouki's & some apple juice.
turbo_dreams is offline   Reply With Quote
Old 12-03-2014, 04:07 AM   #18
Wookie
Wookie's Avatar
Wookie is an unknown quantity at this point
This bitch has varrstoens.
Wookie is offline   Reply With Quote
Old 12-03-2014, 11:44 AM   #19
a-s-silvia
a-s-silvia's Avatar
a-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymore
Send a message via AIM to a-s-silvia
I have 8k cash that is all that is worth, maybe you should give the car to someone since you can't drive it and get the civic of your dreams. 240sx books at $2500 in the best condition even if you did put $50K into that car your ROI is probably $8k but you probably have not taken that course yet.
[SIGPIC][/SIGPIC]
a-s-silvia is offline   Reply With Quote
lengenfelter, one of a kind, perfect, rare, s14
