Old 01-19-2019, 08:07 PM   #1
rfs324
rfs324 is an unknown quantity at this point
s13 to z32 ebrake cable routing
So I'm installing the 2+2 z32 cables on my s13 chassis for the z32 ebrake. I routed the cables through the same path my original ebrake cables took, and it seems very tight, like it will be difficult to get the brackets and everything to bolt up. Is there a different path I should route them? Cut a corner somewhere? I already read importnuts 300zx brake swap page and he does not go into detail about using the 2+2 cables.
Any help would be appreciated.
Thanks!
rfs324 is offline   Reply With Quote
Old 02-14-2019, 03:59 PM   #2
Magoo1222
Magoo1222's Avatar
Magoo1222 has a spectacular aura aboutMagoo1222 has a spectacular aura aboutMagoo1222 has a spectacular aura aboutMagoo1222 has a spectacular aura aboutMagoo1222 has a spectacular aura aboutMagoo1222 has a spectacular aura aboutMagoo1222 has a spectacular aura about
Thanks!
Did you bolt the cable brackets to the chassis in the same position as the original cables? If so, that's your problem. Z32 cable swaps require an adapter bracket for where they mount under the floor. Street Faction sells them
Sent from my Nexus 6P using Tapatalk
Magoo1222 is offline   Reply With Quote
Old 03-04-2019, 05:34 PM   #3
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
yea what he said^^^^
HellaSexyS13 is offline   Reply With Quote
