Old 11-13-2018, 08:34 AM   #1
89fastback
89fastback will become famous soon enough89fastback will become famous soon enough89fastback will become famous soon enough89fastback will become famous soon enough
Fs/ft 1995 Nissan 240sx
Looking to sell or trade my s14 I had all the intentions of using this car for pro am but plans have changed and I need it gone. I am willing to part car out if no interest in buying whole.
Car is set up for a 5.3 v8 but motor is out and ready for a build ( torn down to inspect already ready to send to the machine shop)
Can build it of for 600-800 buy another 5.3 and drop in
Hooker headers
Gm performance wiring harness
Canton oil pan
Sikky oil filter relocation kit
Ls car intake manifold
Ict billet camaro accessory bracket
New water pump
New power steering pump with lines and cooler
New alternator
New crank pulley
-6 an fuel lines
New corvette fuel filter
Wilwood clutch master with steel braided line
Speedway remote bleeder
Camaro t56
(2) spec stage 3 clutches with flywheels
1 zr1 clutch with flywheel
Shim kit for throw out bearing
1 piece drive shaft
Daft motor mounts
(3) radiators 2 regular front mount, 1 for rear mount
(2) welded diffs
(2) new axles and 2 spares
Wild wood brakes with stainless lines front
Spacro seat (beat up)
Koru works steering wheel
Nrg hub
Nrg quick release
Aem oil pressure gauge
Sun pro water temp
Hydro e brake
Pbm eccentric rack bushing
Pbm coilovers
Pbm inner tierods
Spl tie rod ends
Isis tension rods
Pbm front Lca
Joe haven knuckles
Pbm rear upper control arm
Pbm rear lower control arm
Pbm traction rod
Pbm toe rods
Car currently has zenki front end
P2m clear headlight covers
Clear corner lights
Hid bulbs
type u kit
50/50 smoked tails
Roof wing
Sunroof delete
Full roll cage with anti intrusion bars
Painted ford green gem professionally
Also included
Full s15 front end
Rocket bunny front bumper
4 bullit reps 18x9 0 with new tires
6 basket weave 17x10.5+28 with new tires
2 17x9 sve wheels with new tires
Gk tech 25mm spacers to clear the wilwood
Full set of gk tech purple lugs
Full set of black gorilla lugs
And tons of odd ls stuff spare tensioners, pulleys ect
Looking to trade for a street car or sell out right for 10k obo with everything. Call or text 505-712-5975 if no interest I will part out.
89fastback is offline   Reply With Quote
Old 11-14-2018, 12:33 PM   #2
89fastback
Edit car will come with running 5.3 l33 installed
Old 11-27-2018, 12:00 AM   #3
89fastback
Mods please delete car is sold
