Old 04-23-2014, 09:52 AM   #61
hockeyrules
hockeyrules is an unknown quantity at this point
Originally Posted by BiG MiKE86 View Post
Solid aluminum
Thank you!
hockeyrules is offline   Reply With Quote
Old 04-23-2014, 09:59 AM   #62
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Originally Posted by hockeyrules View Post
Thank you!
Check my build thread for pics/fitment stuff
BiG MiKE86 is offline   Reply With Quote
Old 04-23-2014, 10:23 AM   #63
datboibrad
datboibrad can only hope to improve
i thought this setup would have more support than it does but most of the people in my area still prefer the SR
datboibrad is offline   Reply With Quote
Old 04-23-2014, 10:30 AM   #64
RB180sxChris
RB180sxChris's Avatar
RB180sxChris is an unknown quantity at this point
pretty dope thread....might do this swap for my kouki
TOO LEGIT TO QUIT.....
RB180sxChris is offline   Reply With Quote
Old 08-12-2014, 07:41 AM   #65
izzy-
izzy-'s Avatar
izzy- is an unknown quantity at this point
Can someone else make a actual thread that explains how/ and what you need to for the 1jz swap. Maybe somebody like BigMike? This guy basically didn't help at all. He just posted a thread with pics of cars his shop did lol.
izzy- is offline   Reply With Quote
Old 08-12-2014, 07:59 AM   #66
jza240sx
jza240sx's Avatar
jza240sx is an unknown quantity at this point
Theres write ups all over the place about how to put a 1j into an s chassis..
1 jay powa yo!
jza240sx is offline   Reply With Quote
Old 08-12-2014, 08:38 AM   #67
BiG MiKE86
BiG MiKE86's Avatar
LoL I did a 2jz swap but for the most part I think its all the same stuff to do the swap.
My Build Thread
http://zilvia.net/f/showthread.php?t=488537
Flicktitty also has an amazing build thread and is also the creator of the JZ S-Chassis Swap thread
Build thread:
http://zilvia.net/f/showthread.php?t=223490
Sticky Thread:
http://zilvia.net/f/showthread.php?t=384161
Then there is Di-Devol's 1JZ S13 build which is also amazing and probably has all the info you need
http://zilvia.net/f/showthread.php?t=438157
Old 11-02-2014, 07:57 PM   #68
XxS13LifexX
XxS13LifexX's Avatar
XxS13LifexX is an unknown quantity at this point
1jz vvti turbo torque specs
Installed this 1jz vvti Tomei arms 8280 turbo kit today:
Haven't run it yet obviously because I'm still completing my build, but the turbo seems like a nice piece and the kit itself fit flawlessly. For others reference, I figured I'd share this torque spec sheet included in the instructions (note that these are in n*M):
XxS13LifexX is offline   Reply With Quote
Old 02-19-2015, 09:59 AM   #69
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
Didn't realize there was a 1J swap thread and was just using the 2J thread. I'm writing a tutorial to go along with my swap I suppose I will post here instead of making another thread.
Good stuff so far, I should be done by April or so at this rate...a little slow due to the cold and 9-5 life.
bmaddock is offline   Reply With Quote
Old 02-19-2015, 10:50 AM   #70
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
We should just get the name of the other thread change to "JZ Swapped S-Chassis Thread."
This thread had potential but went downhill really quickly.
Old 02-19-2015, 11:14 AM   #71
bmaddock
bmaddock's Avatar
I agree with you.
Mods, is there anyway we can lock this thread and rename the 2J thread to keep it all in one place?
Old 05-31-2016, 08:27 AM   #72
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Anyone running the tomei elbow with a cxracing down pipe? Just wondering if the 3 bolt flanges will line up
corkscrew is offline   Reply With Quote
Old 06-19-2016, 07:23 PM   #73
drifter92
drifter92's Avatar
drifter92 is an unknown quantity at this point
I'm new to JZ engines, I got this vvti 1JZ in a trade for my entire SR20 setup and I've been working on it for a couple months now, it's almost ready to run for the first time. I'm using a CD009 transmission, stock turbo, MAF, injectors, ECU, etc. I will get my AC going ASAP and this will be a car built for Lone Star Drift down here in Texas. Checking in!
Instagram: chinowith
https://www.youtube.com/user/untouchable361/videos
drifter92 is offline   Reply With Quote
Old 06-20-2016, 08:51 PM   #74
drifter92
drifter92's Avatar
Here is where I am tonight
I made my own inlet tube and outlet to get rid of the OEM aluminum air tank
DIY traction control delete
gates barricade fuel lines
dual SPAL 12" electric fans (we will see if they keep it cool)
ceramic/powder coated OEM parts and a FutureFabrication turbo elbow
shaftmasters custom aluminum driveshaft
350Z cd009 transmission
disassembly and new gaskets
Old 06-20-2016, 09:06 PM   #75
drifter92
drifter92's Avatar
DIY transmission crossmember
SPEC twin disc clutch, maverick motorsports cd009 adapter plate
Old 06-20-2016, 09:26 PM   #76
corkscrew
corkscrew's Avatar
Awesome progress dude
Old 06-21-2016, 09:23 AM   #77
bmaddock
bmaddock's Avatar
Wow that is great, quality build! I already wish I went a little more in depth like you did to clean everything. Sort of wish I went with the cd009 too.
Old 06-23-2016, 06:53 PM   #78
drifter92
drifter92's Avatar
thanks guys, I appreciate the support!
Old 06-23-2016, 07:24 PM   #79
TheRealSy90
TheRealSy90's Avatar
You'll do better with cooling if you mounted the fans 1/4" to 1/2" away from the radiator on an aluminum shroud so that they actually pull air through the entire radiator surface, and not just through the diameter of the fans.
Such a good signature.
Old 06-23-2016, 07:53 PM   #80
drifter92
drifter92's Avatar
I'm probably going to move everything forward and run a clutch fan
edit: I cut the core support and i'm moving the radiator and AC condenser forward
Old 07-15-2016, 02:33 AM   #81
Peterxs13
Peterxs13 is an unknown quantity at this point
woah never seen this before
Peterxs13 is offline   Reply With Quote
Old 07-22-2016, 09:56 PM   #82
drifter92
drifter92's Avatar
Just got my car running today!!!!!!!!!!!
https://www.youtube.com/watch?v=xZFpY02xMh8
Old 07-23-2016, 03:57 AM   #83
cole d
cole d is an unknown quantity at this point
Why did you pull the dual fans off ?
cole d is offline   Reply With Quote
Old 07-25-2016, 09:00 PM   #84
drifter92
drifter92's Avatar
I dont want to have overheating issues in the future
Old 08-01-2016, 02:02 PM   #85
bluz370
bluz370 is an unknown quantity at this point
Dean, did you get the full SC300 fan and fan clutch? I cant tell in the pics, but is it offset to the side like all JZs?
I am going through with my swap and was curious what all was needed. Did you go SR rad?
bluz370 is offline   Reply With Quote
Old 08-05-2016, 07:40 PM   #86
drifter92
drifter92's Avatar
Yes its offset, you have to use a MK3 supra fan shroud on the SR20 radiator. I pulled my SR for this JZ so I already had the SR radiator. Koyo triple pass, amazing radiator btw!
Old 08-06-2016, 05:37 AM   #87
corkscrew
corkscrew's Avatar
Any pics of the fan shroud on the sr radiator?
Old 08-07-2016, 06:35 PM   #88
drifter92
drifter92's Avatar
i dont have one yet, but my friend did, search his name as240 on google
Old 10-24-2016, 10:39 AM   #89
Teister
Teister is an unknown quantity at this point
Unhappy
Hey im trying to figure out what some of these connectors are on my 1jz non vvti engine harness.. anyone know?
Teister is offline   Reply With Quote
Old 05-16-2017, 08:50 AM   #90
drifter92
drifter92's Avatar
https://www.youtube.com/watch?v=mqAzJRkheSc
I got my car drivable today after LOTS of work, replaced head gasket, ARP head studs, decked head, valve job, Collins Adapter plate, competition stage 3 clutch, serial9 cd999 shifter relocation, stock VVTi 1JZ, stock MAF, injectors, ecu, boost, turbo, all stock
