Old 03-25-2010, 04:06 PM   #31
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
Originally Posted by E Double View Post
i asked this in another thread and wasn't really satisfied by the one answer i received. since there is intelligent discussion going on here i'll ask you guys.
when doing head work, if you only replace the springs and retainers do you need to re-shim everything or will the stock shims still suffice?
i.e. replacing stock springs and retainers with BC springs and retainers
valve height wont change. just make sure you label each and every one when you take em out
Bye bye zilvia kiddies
aNskY is offline   Reply With Quote
Old 03-25-2010, 04:43 PM   #32
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
yeah, i have heard that several times. i plan to separate everything into marked sandwich baggy's because i want to get the head deck and hot tanked.
Old 05-01-2011, 01:26 AM   #33
yabeet
yabeet's Avatar
yabeet is an unknown quantity at this point
Is the OEM SR head gasket .8mm or 1.1mm? I am finding conflicting results.
Reason being the block I bought needed to be decked .25mm!
I will also have to remember to shave the front cover, good thing I looked through this thread to remind me.
PS sorry for bumping an old thread.
The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power sta– I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’
Jeremy Clarkson on Automatics
yabeet is offline   Reply With Quote
Old 05-23-2011, 06:40 PM   #34
mystacarlo
mystacarlo is on a distinguished road
I have a stock bore block 86m, so the general idea from this thread is i shouldnt have any problems using a 87m head gasket from apexi
mystacarlo is offline   Reply With Quote
Old 05-24-2011, 09:32 AM   #35
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
Limit is .2mm between head and block iirc.
If you decide to increase your chances with a larger head gasket, I'd highly recommend you still check valve clearances.
By you even looking for the information though, you may already know that. Just checking.
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 01-19-2016, 12:29 PM   #36
Turb
Turb's Avatar
Turb is an unknown quantity at this point
So I want to order a head gasket kit from frsport and the head gasket is 87mm bore and my motor is completely stock which I'm pretty positive is 86mm bore, am I going to run into any problems?
Turb is offline   Reply With Quote
Old 01-19-2016, 01:01 PM   #37
harrypotter
harrypotter is an unknown quantity at this point
way to revive a way old thread...but here you go
****FOR 86MM (STOCK BORE) ORDER 87MM GASKET****
http://www.enjukuracing.com/products...eadgasket.html
http://imageshack.us/photo/my-images/842/zilviasig.jpg/
harrypotter is offline   Reply With Quote
